Tundra brakes on a 3rd Gen
Old Jul 13, 2007 | 10:27 PM
  #81
Midget96's Avatar
You guys just don't stop. One more time...
Originally Posted by RoySharif
Doesn't the Tundra/Sequoia caliper have bigger pistons aside from having wider pads? bigger pistons translate to bigger force on the rotor which then translate to bigger stopping force.
No. The pistons are the same diameter. The calipers are identical aside from being marginally wider with a slightly wider body.
Originally Posted by crbocaj125
Well, I thought that was better, but according to midget, those are just "dilusional benefits"
Wow. A pad that is .004" thicker, .01" longer and .19" taller. That's really going to make a drastic difference. If you want to give your micrometer a work out, then you're right on target, but your comparison is totally irrelevant to a difference in braking performance.
When I had Wilwood calipers, I used pads from Hawk, Cobalt Friction and Raybestos, and every brand had a different pad profile and overall shape. Guess what? Zero difference in performance in terms of the shape. The material on the pad is what does the work, not how much of it is on there.
Here's a nice article about what goes into an actual brake upgrade. There's also some proof that even a REAL brake upgrade does not drastically improve stopping distance.
http://www.sportcompactcarweb.com/pr...t_3/index.html
And don't come back here saying "You can't compare a Matrix to a 4Runner." WRONG. The principles of a good brake system are the same whether it's an F1 car or a mountain bike. That Matrix, even with a 4 wheel StopTech big brake kit with massive two piece rotors and aluminum 4- and 2-pot calipers, didn't differ much from the stock brakes in their 60-0 tests. The only thing the big brakes excelled at was fade resistance (Tundra brakes may do this), pedal feel (Tundra brakes have no effect on this) and heat capacity (Tundra brakes would do this if you tow).
Want a real upgrade for the 4Runner? Try adding some rear discs off an 03+ 4Runner...
Old Jul 14, 2007 | 09:56 AM
  #82
frodin1's Avatar
WHY is this still an issue?
Old Jul 16, 2007 | 06:20 AM
  #83
MTL_4runner's Avatar
Yeah, that's because most of the braking is done by the rears right?!
Just keep ignoring reality and substituting your own.
I'm sure if you're persistent enough some poor gullible soul will eventually believe you.
Old Aug 10, 2007 | 08:37 AM
  #84
Ringmaster's Avatar
Wow it's all about better brakes.
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
93toyoguy
Aug 2, 2015 07:41 PM
vanion2
Jul 29, 2015 06:17 PM
Suprarossa
Jul 6, 2015 05:21 AM
