Old Mar 30, 2016, 11:13 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Electrical Guides
Print Wikipost
Truck won't start after replacing battery terminals
Old Oct 2, 2013 | 03:09 PM
rworegon's Avatar
Originally Posted by 1371engineer
Cut the old positive off and connected the new terminals and connect the ground wire off the positive wire.
No, you cut off the neg terminal from the negative wire and replaced it with a red terminal.......it is still the neg battery cable now with a confusing terminal color.
Old Oct 2, 2013 | 03:56 PM
1371engineer's Avatar
The old one I cut off was also red
Old Oct 2, 2013 | 04:26 PM
So I switched the battery around and now I get nothing at all? Checked the fuses in the cab and all look good
Old Oct 2, 2013 | 04:29 PM
frm_808's Avatar
What about the eng bay fuse panel? You may have blown the main fuse
Old Oct 2, 2013 | 04:38 PM
  #25
rworegon's Avatar
Ok, so the terminal you cut off was red, but WHAT is the polarity of the wire that you cut it off from? The terminal color really means nothing.
There are plenty of threads here from people hooking batteries up backwards and the fixes will show up when you do a search.
Blown fusible link or 80 amp fuse is where I'd look first.
Old Oct 2, 2013 | 04:57 PM
  #26
Checked all fuses they are good. Only thing that happens now when I try to start is the seat belt indicator
Old Oct 2, 2013 | 05:14 PM
  #27
rworegon's Avatar
Do the headlights or interior lights work? Can you tell if anything other then the seat belt indicator is getting juice?
You are certain the 80 amp fuse in the fuse box under the hood is good?
Old Oct 2, 2013 | 10:48 PM
  #28
RAD4Runner's Avatar
Originally Posted by rworegon
That wire to the fenderwell is correct on the neg wire......he is connecting the cables incorrectly to the battery.
Correct, rworegon
OP,
Please verify what I noted on pic below. Once verified,
Battery should be turned around.
Terminals should be be switched.
Green quick-disconnect should go to black wires near fender. That's usually where negative terminal of battery should be. Quick disconnect belongs on negative of battery because it is the negative that should be disconnected first before working on electrical circuits.
Red terminal should be connected to wire that goes to starter and white fusible link wire.
White wire is most likely fusible link wire that should connect between batt + and fuse block.
Then, look at your schematic so you can do voltage checks, etc. Specify what truck you have. That way people can look up or share their schematics.
Unsubscribed...
Old Oct 3, 2013 | 01:49 AM
  #29
Thanks a lot. It's a 01 tacoma 5vz fe
Old Oct 3, 2013 | 03:35 AM
  #30
ARB1977's Avatar
Did you get the 34R or just 34? You need 34R.
Crazychris1871
Jun 27, 2016 10:38 AM
newzingo
Jun 24, 2015 01:50 PM
Taz22R
Jun 21, 2015 04:44 PM
Dennis140
Jun 17, 2015 10:37 AM
Corey
Jun 10, 2002 04:23 AM
