Truck Wont Go Into 4-LOW. NEED HELP!
Old Mar 2, 2004 | 05:53 PM
Attrayant's Avatar
Hey all
I have a 1988 Toyota Truck 4x4 22RE. The truck goes into 4-High without a problem but i cannot get 4-Low in engage at all. Any help would be greatly apprechiated. Thanks.
Old Mar 2, 2004 | 06:04 PM
lunatic14r's Avatar
NEED MORE INFO what happens grinding stick dont move truck dont move?????
Old Mar 2, 2004 | 06:14 PM
kford's Avatar
put in neutral lol yeah need more info.
Old Mar 2, 2004 | 06:33 PM
Attrayant's Avatar
lol guess I was in a rush. When I go to put it in 4-Low and try to drive, truck goes nowhere, just revs up like its in neutral. If I hold the shifter forward and try to go it grinds.
Old Mar 2, 2004 | 06:36 PM
Jonathan's Avatar
Do you have a body lift?
Old Mar 2, 2004 | 06:49 PM
lunatic14r's Avatar
or a beat up truck
Old Mar 2, 2004 | 07:18 PM
Attrayant's Avatar
Its not beat up, but it does have a 3" body lift.
Old Mar 2, 2004 | 07:43 PM
Glenn's Avatar
That should be your first clue. The body lift is making the 4wd lever bind against the opening. You may need to rebend the lever.
Old Mar 2, 2004 | 07:49 PM
Jonathan's Avatar
Yeah that's what I was thinking. When you lift the body that far it changes the position of you shifter levers so much that they sometimes won't go into position. Take off you shifter boot and there should be a metal plate underneath. If you grind that plate it should allow the shifter to move more freely.
Jonathan
Old Mar 2, 2004 | 07:53 PM
Attrayant's Avatar
Jonathan
I'll take a look at it, by grind the plate you mean cut it out some?
Old Mar 2, 2004 | 08:13 PM
Jonathan's Avatar
Yeah. There should be a metal plate kind of like a surround at the bottom of the shift boot. Once you lift the boot you will see it. Go through your gears and see if the stick is hitting the metal plate. Wherever it hits, is obviously where you need to notch out some of the metal. Once you get in there you will understand what i'm talking about.
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
thelifeadventure
Jul 2, 2015 03:09 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
