truck leaning to the right
Old Feb 4, 2004 | 11:36 PM
BigJohn's Avatar
when driving my truck wants to go to the right , my tire pressure is all good, is it the rotors?
Old Feb 5, 2004 | 02:25 AM
Tacoma Dude's Avatar
How's your alignment?
Rotors could be a cause but I'd put my money on your alignment.
Old Feb 5, 2004 | 03:02 AM
Breezey's Avatar
Guest
If you mean, it wants to go right a tiny bit... all toyota do that, or at lest all of the ones I have owned. I would alway have to turn the weel a tad to the left... on real nice smooth roads, for the most part it drives strait
Old Feb 5, 2004 | 03:03 AM
WT's Avatar
WT
I'll second the alignment.... guess its possible its a stuck caliper if its only occuring during braking but you didn't mention that.
Old Feb 5, 2004 | 03:10 AM
Yoter's Avatar
Guest
Question Leaning or pulling?
Leaning & pulling are to different things. If it leans then it could have a weak spring or torsion bar causing the lean or one hell of a fata$$ bumming rides from you. Now if its pulling when simply driving down the road the guys are on the right path with your alignment being off. If it pulls but only when your braking you have a stuck caliper. Hows the tires, wearing on the inner or outer edges? Blue
Old Feb 5, 2004 | 08:22 AM
CMD93's Avatar
I believe that roads are engineered so that they are not perfectly flat, which aids in the rain runoff. Maybe its just the road being arched slightly that makes it seem like the truck is pulling to the right.
Or maybe your alignment is off or your tires are not balanced correctly?
Just my 2 cents.
Old Feb 5, 2004 | 10:04 AM
Plays_with_Toys's Avatar
I would drive on various roads in different areas.
My truck pulls to the right on some roads, not on others. Also, in some intersections, where the road is worn pretty badly, the truck will pull even harder, but it is because of the ruts.
Old Feb 5, 2004 | 10:05 AM
BigJohn's Avatar
well better use my warranty i still have 10 months of it
Old Feb 5, 2004 | 03:11 PM
kford's Avatar
Not enough downforce. Put a huge wing on it. here's an example:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33638
It will also add 20-30 HP. And if you can find a decal from the manufacturer of the wing, stick it on your rig. Another 4-5 HP.
Old Feb 5, 2004 | 04:17 PM
lanai's Avatar
Did you just lift your truck or changed shocks or springs?
I changed my shocks and springs two weeks ago and I noticed that the truck steered toward the right.
I did an alignment and the problem went away.
sonic concepts
Aug 16, 2025 03:13 PM
Ichneumon
Sep 27, 2015 04:21 PM
MadMax48
Jul 3, 2015 08:26 AM
Jake28296
Jun 27, 2015 07:24 AM
94hiluxZE
Jun 22, 2015 10:42 AM
