Trouble Turning Over
Old Jul 11, 2004 | 09:16 PM
amusement's Avatar
Fooddude I had a '95 Toyota SR5 4x4 that would die while running, hard starting but, recooped to run then died again. I discovered the EFI relays were failing.
A 95 has two relays supporting the EFI system.
1. Located in the fuse/relay box under the hood passenger side
2. Located under the dash between the ignition switch and the left side of the heater vents.
I replaced -both- relays and my problem was solved. It was a cheap date. Problem truly was I didn't know (at the time) I had two relays.
Old Jul 15, 2004 | 02:55 PM
fooddude's Avatar
Well i took it to my mechanic, and after a couple days of even him being stumped he found out that my remote start system was doing something to turn my car off. He took it out and it has been running perfect ever since. Thanks to everyone who tried to help me.
okamikai
Apr 30, 2018 10:19 PM
Shoua
13
May 22, 2016 05:19 AM
skoob
Oct 15, 2015 03:23 PM
mtc1105
Aug 4, 2015 08:06 PM
Hamonacracker
Jul 17, 2015 08:33 AM
