Tricks for changing 22re fuel filter
Old Jan 31, 2005 | 01:18 PM
ekim121's Avatar
Like the title says...I was going to change the fuel filter on my 22re and then went and took a peek under the hood. Needless to say I was less than enthused with what I saw. Does anyone know of any good tricks to get that out of there? Thanks
Old Jan 31, 2005 | 04:40 PM
93bluetoyota's Avatar
I heard it is a PITA to change. Other than that I have no ideas for you...Sorry
Old Jan 31, 2005 | 04:58 PM
4Hummer's Avatar
Jack the truck up.
Remove the Passenger Side Tire.
Remove The inner fender piece. (I belive it 2 bolts..its kinda like an access panel)
I found thats the easiestt way to get to it.
Other than that a 3" Body Lift makes it even easier
Old Jan 31, 2005 | 05:03 PM
bike4miles's Avatar
Originally Posted by 4Hummer
Jack the truck up.
Do you seriously take the wheel off? I just reach down next to the bat. and put the tool on but I think I usually push forward with the handle on the top side of the filter rather than pull from the underside like you normally would because it seems to fit in there better that way. To put the new on I just clean my hands and tighten it by hand as good as I can.
Old Jan 31, 2005 | 05:15 PM
4Hummer's Avatar
Yeah Ive always Pulled the passenger SIde tire off and that acess panel. Maybe our engines are differant ??
THERE is NO way I could get to it under the battery.
Old Jan 31, 2005 | 05:18 PM
BLKNBLU's Avatar
I did like 4Hummer. I can't imagine getting at it from above.
Mike
Old Jan 31, 2005 | 05:39 PM
DeathCougar's Avatar
Now how exactly do you remove/install a FUEL filter by grabbing it and unscrewing/screwing it by hand? Must be a new filter design on a 22re...damn aftermarket.
In terms of the fuel filter, dont take the tire off. Just remove the access panel. then use a 17mm Box wrench to take the banjo bolts out, then use a 12mm socket to remove the filter from the bracket. Installation is reversal of that. Make sure you use new Brass washers for the banjo bolts, or it will leak. Trust me, i ran into that problem.
Old Jan 31, 2005 | 06:24 PM
Yamaha+Toyota=Fun's Avatar
I just pulled off the whole intake. It make it 100% easier than others Ive done. You can also clean the whole intake, injectors, etc. I second using new brass washers, cheap insurance.
Old Jan 31, 2005 | 06:25 PM
cabbage's Avatar
I guess the easiest way would be take the engine out!
I dont see how you can get to it from the top, its directly under the intake right above the starter!!
I remember the last time I did it was what 4hummer said. I know some guys like to use the crows foot... I thought the new filter came with the washers too?
Old Jan 31, 2005 | 06:31 PM
bike4miles's Avatar
Woops, I'm an idot and thought you were talking about the oil filter! I went in from the side to get at the fule filter with a 6" 1/4" drive extention and 12mm wobly sockett. I took part of the fender well out but I didn't take the wheel off. I just slithered my 125 pound body between the tire and fender well. Getting the old one off was much easyer than getting the bolts to line up when installing the new one.
Old Jan 31, 2005 | 06:38 PM
waskillywabbit's Avatar
I don't think I'll have a problem getting to it...and yes, those copper washers on banjo fittings are a must or it will leak...I found that out on my rear discs when I forgot them...
Old Jan 31, 2005 | 06:40 PM
PirateFins's Avatar
Damn Cabbage you beat me to it. I just had the head off and the fuel filter was a piece of cake to change. Just reached in and wrenched it off and put a new one on 5 mins tops. Now if someone can tell me where all of these bolts go I'll be back up and running, with clean gas I might add.
Like what has already been said, take the tire and the access cover off and reach in that way. You can also turn the tire all the way to one side or the other but taking it off is way better.
Old Feb 2, 2005 | 02:27 PM
Tacoma Dude's Avatar
I have fender flares and was able to do it without removing the tire with a series of extensions and hugging the tire.
I'll be taking the tire off next time.
smthwsn357
May 1, 2024 07:28 AM
jbv808
Aug 6, 2021 04:47 PM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
