Trick to removing rear differential???
Old Aug 23, 2009 | 10:40 AM
crolison's Avatar
Lower the truck to the jackstands so the rear axle sits on them.
Old Aug 23, 2009 | 12:38 PM
vital22re's Avatar
totally a bro
make sure you clean your diff breather!!! may be the reason you're leaking.
Old Aug 23, 2009 | 12:44 PM
chubbydude's Avatar
I did a e-locker swap on my 90 a few months ago. The top studs on my diff were rusted to the casting, so I spent a lot of time hammering, chiseling etc and could not get it split with the axle out of the vehicle. I eventually drilled out a couple of the top studs, and that worked.
Old Aug 23, 2009 | 12:50 PM
Pigman's Avatar
Well, did you get her to break loose ??? A lot of 3rd members are sealed with FPIG (form in place gasket) and once that sets up they stick pretty good, go with a stiff putty knife and a hammer, it should come loose, also I swear by that black FIPG toyota sells, you won't have anymore leaks in that area. It's good for engine repair as well, it won,t take out o2 sensors like some silicon sealers. Good idea checking that vent!
Pigman
Old Aug 23, 2009 | 06:09 PM
  #25
crolison's Avatar
yeah use permatex sealant for when you put the diff back in
Old Aug 23, 2009 | 06:20 PM
  #26
Matt16's Avatar
Place jack under pinion flange. It will work guaranteed.
Old Aug 23, 2009 | 08:08 PM
  #27
vegascoug's Avatar
Done!
I used permatex (elephant snot as my mechanic brother calls it) to help seal the gasket.
Replaced both inner seals, the diff gasket, new drums and pads (shoes were SOAKED with oil and the drum was rusted and coated in oil/mud) now I just have to fill er back up and bleed the brakes and I'm rollin!
Ladythump
22
Nov 9, 2015 08:53 AM
jerusry
Oct 19, 2015 05:28 PM
icentropy
Jul 14, 2015 10:23 AM
AaronM
Jul 8, 2015 07:15 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
