Transmission problem, need help?????
Old Jul 2, 2005 | 05:51 PM
YeloSub7's Avatar
Question Transmission problem, need help?????
My 1994 toyota 4runner auto tranny has sorta taken a dump. It hecka slips, so I thought no brainer, I need a new tranny. But the thing is it still works totally fine in 4wd low. So anyone who knows how these trannys are set up with the transfer case please help me out. I am pretty sure I need a new tranny. My only confusion is that it works in 4wd low with no slipping whatsoever. So anyone with knowledge that could point me in the right direction would be greatly appreciated.
Thank you...
Old Jul 2, 2005 | 08:20 PM
superjoe83's Avatar
there is much less load placed on the trans while in 4low, so it doesn't slip as bad (not enough for you to notice)
Old Jul 2, 2005 | 09:04 PM
Cebby's Avatar
Have you checked your fluid level lately? Low fluid will cause slipping...
Old Jul 2, 2005 | 11:40 PM
YeloSub7's Avatar
Ya I checked the fluid and is fine, and I just replaced the fluid a couple months ago anyways. So you think its basically shot then??? Is there anything I can do to fix the problem or just buy a new tranny???
Old Jul 3, 2005 | 06:08 AM
Beartracker's Avatar
New or rebuilt tranny is the way to go and may be the only answer to your problem. Some people claim that changing the fluid can cause problems on older models but I don't know how true it is.
Old Jul 3, 2005 | 06:34 AM
Captain_Toyota's Avatar
When you replaced the fluid, did you just drop the pan or did you get it completely flushed out?
If merely dropped the pan, there is still a lot of old, junky fluid in the torque converter that could be making your tranny perform poorly.
Cap'n
Old Jul 5, 2005 | 03:15 PM
YeloSub7's Avatar
So anyone know of some good places to get it rebuilt, or whewre to buy a used one?
Old Jul 5, 2005 | 03:16 PM
YeloSub7's Avatar
and roughly how much it would cost?
Old Jul 5, 2005 | 05:57 PM
Probably $1000 for a rebuild of your tranny, probably AT LEAST $2000 for a new one.
Cap'n
Old Jul 6, 2005 | 10:21 AM
YeloSub7's Avatar
ok thanks...
Old Jul 7, 2005 | 03:45 PM
YeloSub7's Avatar
one more thing, are there kits to rebuild a tranny yourself? $$$ and where? how?
Old Jul 7, 2005 | 04:21 PM
naksukow's Avatar
http://www.importperformancetrans.co...uto.shtml#main
http://www.levelten.com/store/import...rts_toyota.htm
They both offer kits and manuals to DIY.
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
