Transmission plugs - what size socket?
Old Mar 19, 2004 | 11:15 AM
JohnStra's Avatar
What size sockets do the plugs on the manual tranny take?
Old Mar 19, 2004 | 11:40 AM
Yoter's Avatar
Guest
Should be 15/16s
Old Mar 19, 2004 | 11:47 AM
JohnStra's Avatar
Argh! I've got a 7/8" and a 1 1/8"!
Thanks.
Old Mar 19, 2004 | 11:52 AM
Flygtenstein's Avatar
How about 22 or 24 mm?
I would be impressed if you have standard fittings on a Toyota.
Old Mar 19, 2004 | 11:55 AM
Yoter's Avatar
Guest
Fine get all technical on me. Ive always used my one and only standard socket (15/16) and its worked fine. Thanks for the correction Fly
Old Mar 19, 2004 | 06:17 PM
outdoorfever's Avatar
should be 22
Old Mar 19, 2004 | 06:35 PM
Yoter's Avatar
Guest
Should be but could be 1516 if say you dont have a 22.
Old Mar 19, 2004 | 06:58 PM
toy283's Avatar
24mm. There's nothing on a Toyota that uses a 22mm (at least that I know of).
Old Mar 19, 2004 | 07:36 PM
JohnStra's Avatar
My manual tranny only took a little less than 3 quarts. Manual says it holds 3.2. Tranny was hot and on level ground. Anyone else replace theirs lately and it take less than the book says it should? Must not have gotten it all out cause its right at the filler hole.
Oh, and my buddy's 15/16 worked just fine.
Old Mar 19, 2004 | 08:46 PM
Nic's Avatar
Nic
Sounds like mine. My transmission holds just under 3 quarts after a total drain.
Old Mar 20, 2004 | 06:26 AM
My t-bar bolts are 22mm which means the tranny and axle drain and fills are 24mm by process of elimination. FYI, the low pro drain plugs for the diffs are a PN for tranny plugs.
Old Mar 20, 2004 | 08:47 AM
platform389's Avatar
I would be equally impressed if he doesn't round off the head and/or bust his knuckles in the process.
Using SAE on metric fitting is just begging for trouble.
Old Mar 20, 2004 | 10:17 AM
Nic's Avatar
Nic
Some SAE sockets work equally well on a metric. I think 13/16 is the same as 17mm. I found that out when installing Hella auxillary lights and the manual said use either one. It was true. I needed a 17mm deep socket and I only had a 13/16, so that's what I used. It fit exactly.
However, its a lot more practical to forget about using SAE on a Toyota. Buy some good metric tools. Consistently trying to find the right SAE on a metric vehicle is not practical in my opinion.
BTW, my tranny uses a 24mm drain and fill plug. Whatever size yours is, use a 6 point instead of a 12 to avoid rounding the head.
Old Mar 20, 2004 | 03:44 PM
SolidDigital's Avatar
I use 15/16 on mine too, do you guys have magnetic drain plugs on your transmissions? I have magnetic ones on the transfer case, front & back diff., but not the tranny...
Old Mar 20, 2004 | 04:01 PM
Nic's Avatar
Nic
Mine is not magnetic either-just the others.
Old Mar 20, 2004 | 04:09 PM
Yoter's Avatar
Guest
Originally Posted by Nic
Some
12 points suck arse
Old Mar 20, 2004 | 04:13 PM
I wonder what the reasoning was behind this? to me if it had a magnetic one, it'd be a lot better for the transmission
Old Mar 20, 2004 | 04:17 PM
Yoter's Avatar
Guest
I would assume the mag ones were factory. The non mag ones are more than likely AFM stuff due to stripped plugs or lost ones. Thats my A$$umption.
Old Mar 21, 2004 | 03:25 AM
toy283's Avatar
Originally Posted by BigBadBlue
12 points suck arse
Usually. When used on 12-point nuts & bolts they are essential. I have quite a few of those on my engine because they are much more difficult to round off than 6-point.
Old Mar 21, 2004 | 07:39 AM
4Crawler's Avatar
I use a 24mm, 6-sided socket on mine, 15/16" is also close enough. I've converted my remaining plugs over to the low-pro plug with the 10mm socket.
