torsion bar crank?
Old Oct 7, 2004 | 08:01 PM
lbb-1's Avatar
bolts?
Old Oct 7, 2004 | 10:12 PM
jimbo74's Avatar
as mentioned above on 86-88 the bolt can sag through the adjuster!!!!
yes...... look up my post on the "broken anchor arm" this happened to my 85 IFS 4x2....
upgraded with a version from the 89 era... new design... diagram in that thread.....
Old Oct 7, 2004 | 10:43 PM
jimbo74's Avatar
https://www.yotatech.com/attachment....achmentid=4076
Old Oct 8, 2004 | 03:12 AM
mt_goat's Avatar
Originally Posted by lbb-1
can the bolts be upgraded to a stainless steel if so what size kind ect??
thanks
Why would you want SS bolts? SS bolts suck. They gall much easyer and are not as strong. The only upgrade you could do would be to a metric class 12.9, but get out your check book. If you could find them they would probably be about $25 each. The best thing is just to keep the stock bolts and keep them lubed up good with a thick coat of grease.
Old Oct 8, 2004 | 03:35 PM
  #25
elripster's Avatar
Good news, stronger bolts should be cheap. Typically the cap screw is Class 12.9 and the bolt class 10. I'm not exactly sure of why that is. But, you can get som big old bolts for about 60 cents each at www.boltdepot.com. Also, you can check www.mcmaster.com.
However, given the typical life span of the t-bar bolts, as said, a little grease should keep 'em in good shape for years and years.
Frank
andrewtexas123
Jul 6, 2016 01:49 AM
89fourrunner
Feb 17, 2016 06:52 AM
Steven.m.paulk
Aug 16, 2015 04:52 AM
mavenator
Aug 13, 2015 01:12 AM
coffey50
Jul 28, 2015 10:55 AM
