tire ?
Old Sep 11, 2004 | 01:05 PM
crghou's Avatar
tire ?
So I have a stock tacoma....v6 auto....And I am going to put a 3in suspension lift on it probaley w/ a differential drop and I dont know about the back yet. But....What size tires should I go w/? I was thinking of 33x12.50's but I want to know if that is going to cause many problems w/ stock gearing and what not.
Thanks
Old Sep 11, 2004 | 01:32 PM
jimbo74's Avatar
depends what gears you have now and also what size your current tires are... there will be some loss in performance, but until we know what the gear ration you have now and what size tires you have, ther eis no way of calculating
Old Sep 11, 2004 | 02:03 PM
crghou's Avatar
current tires are 31x10.50's on 15x7's. I have no idea about the rear end size. How would I find out?
Old Sep 11, 2004 | 02:43 PM
jimbo74's Avatar
look for an axle code on your door sticker or under the hood
Old Sep 12, 2004 | 11:21 AM
crghou's Avatar
Well I can't find it yet so I am looking somewere else. All I know is that the truck is badged w/ a TRD sticker and that it dosn't have the electronic locker. It doea have the manual hubs up front though and it is an auto tranny. I dont know if that helps.
Old Sep 12, 2004 | 11:30 AM
superjoe83's Avatar
you will probably be ok with power, i went from 31x10.50's to 33x12.50's on my 2.7 5speed taco, and didn't loose much power
and the fact that you have an auto i would bet that you have a 4.56 ratio
Old Sep 12, 2004 | 11:34 AM
crghou's Avatar
Talking
How was your braking afterwards? My brakes kind of suck as is and no ABS for me...
Old Sep 12, 2004 | 12:00 PM
superjoe83's Avatar
well i cant answer that accurately, because i already had stainless steel bake lines installed, but i can lock all 4 on dry asphalt if i try, heres a link for the lines http://www.4wheelparts.com/4wp/produ...RO&expand=sub8
Old Sep 12, 2004 | 01:12 PM
crghou's Avatar
so anyone else do this as well w/ no problems?
Old Sep 12, 2004 | 01:33 PM
UTKtacoma's Avatar
Ive got a 98 Tacoma v6 5spd and I am running 32X 11.50 AT's under a 2.75" lift (SAW Coilovers and TM ADD-A-LEAF and Bilstein 5100's). I trimmed the plastic of the innner fenders covering the pinch weld, but didnt flatten the pinch weld, and i have no rubbing issues what so ever. As far as power goes, you wont notice any difference. Ive got stock 4.10 gears , and im willing to bet that you do too. As far as I know, the only Toyota that came stock with 4.56 is some sort of 2nd generation v6 4 runner, not positive though. I know guys running 33x12.50's on stock gearing with auto tranny's, and still dont have too much of a power loss. So to answer your question, you will be just fine with 3" and 32x11.50's on stock gearing.
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
