timing belt w/p etc. replacement??
Old Oct 2, 2009 | 11:03 AM
Adelski's Avatar
I'm looking to do this pretty soon so a good write-up would be awesome. Can't wait for the info y2k!
Old Oct 2, 2009 | 12:58 PM
Parker Runner's Avatar
There are pros and cons to both sides. Once you tear something apart, you need to know how it goes back together. Dealers and repair shops all the time only replace the bad parts. However, if you takes something off, and it is cheap to replace, why not get the free labor and put it back on?
I think you can go overboard. If you are going to replace all the bearings and seals, why not check the valves. Why not rebuild the head while you are in there? Why not rebuild the long block?
Now, I think it might be a good time to replace the radiator, put in some Evan's coolant, replace all the belts etc. If you feel the need to replace the waterpump, go for it.
Bottom line, you don't want the timing belt or parts under there going on you in the middle of nowhere.
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
layifioren
10
Jul 6, 2015 02:26 PM
marcusSRG
Jun 27, 2015 07:13 AM
infinityisfive
Jun 16, 2015 06:51 PM
