Tensioner pulley, I cant get it to loosen up!
Old May 10, 2008 | 08:30 PM
312necro213's Avatar
Okay so I got it all taken apart and I need help with the tensioner pulley I cant get it to loosen up, any help is appreciated I have a picture attached of the little piston thing I can't get to loosen.
Old May 10, 2008 | 09:14 PM
fillsrunner4's Avatar
Dude you have to remove the entire unit. That piston will not come out like that and should not. it has two bolts below. Losen evenly and the entire unit will come out as one. You will need a press to compress the "piston" piece back to were it belongs. I sujest a whole new one. It will come with all you need. Read a manual before you look to do this agian.
Old May 10, 2008 | 09:28 PM
Elvota's Avatar
Fillsrunner4 is right (as usual)
This tool, or similar... will also work if you can't remove the tensioner:
http://buy1.snapon.com/catalog/item....&group_ID=1552
Old May 10, 2008 | 09:42 PM
Ive got my wrong moments too
kawazx636
Oct 6, 2021 03:03 PM
Dale Johnston
11
Oct 31, 2015 10:22 PM
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
EVars
Sep 29, 2015 02:06 PM
