synthetic winch cable
Old Oct 19, 2002 | 06:19 PM
data's Avatar
Senior Member
I'm in the market for some synthetic winch cable. Today after winching twice with the wire rope I have decided to make the switch. After only using it twice it has gotten caught up and tangled like hell. If I would have been in the woods alone trying to get this stuff un-tangled, I would have been ˟˟˟˟˟ed! I had fun though pulling a JEEP out TWICE Where is a good place to buy synthetic cable online? Corey, I searched your site and found some excellent information
Old Oct 19, 2002 | 06:40 PM
Corey's Avatar
Co-Founder/Administrator
Aye, Data. Good choice to switch.
www.masterpull.com
www.rockstomper.com
Some good reading:
http://www.4wdandsportutility.com/te...94wd_stronger/
You saw the links I had then on my site to the other write-ups?
There is a new line out now even better than the stuff I have.
Here's the article:
http://www.4x4wire.com/reviews/oro_xline02/
I still like my line though, it's already pulled out a stuck Toy in the snow last April.
When you get it, you will wonder why you ever used the steel cable.
Old Oct 19, 2002 | 07:28 PM
data's Avatar
Senior Member
i can still use my current warn snatch block with this synthetic stuff correct?? Also would it hurt anything to move up to 150ft of rope vs. my current 125ft? I was just curious if the 9500i could hold 150ft worth.
Old Oct 19, 2002 | 07:56 PM
Corey's Avatar
You can use your current snatch block with no problems.
I run 100' of the 5/8" or 5/16" line.
I forget which, but it's what they recommened, and the same size as the wire rope that that came on the winch.
Not sure how much you can fit on there, they should know when you order it.
Old Oct 20, 2002 | 09:05 AM
data's Avatar
Senior Member
I read somewhere that exposure to the sun for a period of time will damage & break down the synthetic cable. I've noticed that lots of other aftermarket bumpers have the winch sort of "hidden" from view unlike mine. Has anyone ever ran into any problems like this that you know of? Mine is exposed majorly to the sun b\c it is out in the open. I suppose I could buy a cover
Old Oct 20, 2002 | 09:14 AM
Corey's Avatar
Yes, the ARB & TJM's are the "hidden" winch design.
You also have to take the bumper off to even get to the winch.
Good for theft prevention.
I'd say make a custom cover for yours to keep the line out of the sun.
The line is treated with a UV protectant though.
Maybe rub some sunblock 40 on once a month
I'm sure you could come up with some kind of a cover for it.
How about the place that built it?
Maybe a clip on light weight alloy cover, or black plastic?
Warn does make winch covers out of plastic & vinyl.
Here's the page.
They have covers also for the roller fairlead which would stop the UV from coming in that way also.
Old Oct 23, 2002 | 07:06 AM
data's Avatar
Senior Member
the rope effected by cold temps also? i couldn't find any specs on cold, but i did find some on the heat.
Old Oct 23, 2002 | 07:47 AM
Corey's Avatar
I don't think cold will matter.
These ropes are used on ocean going vessels year round.
Old Oct 23, 2002 | 08:00 AM
Arnold's Avatar
I use a thick sheet of rubber to keep my rope protected from the elements.
Old Oct 23, 2002 | 08:39 AM
Corey's Avatar
Nothing like a rubber to protect your goods, er I mean line
Old Oct 23, 2002 | 04:33 PM
Arnold's Avatar
LOL.
kawazx636
Oct 6, 2021 03:03 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
Phantez
Sep 30, 2015 08:24 AM
rmill05
Sep 27, 2015 01:43 PM
Rcbc92
Sep 26, 2015 03:00 PM
