switch
hehe i didnt fly out when i tried it but it doesnt start unless the clutch is pressed i tried. the light goes on when the ignition is on and unable to turn the light off till i turn the ignition off.
Im positive its the Clutch Cancel Switch (CCS). Insert key, turn to on, press that button, and start...
ONLY do that if you are absolutely positive that your truck is not in gear, and the e-brake is on..
Not true, you can accually use it to drive your truck a short distance. Put you truck in gear, press the CCS and turn the motor over. Can be helpful in some situations....
kawazx636
Oct 6, 2021 03:03 PM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
OR the clutch cancel switch....
