switch
Old Apr 9, 2005 | 03:11 PM
shizfu's Avatar
switch
anyone know what this switch is? it is located on the left of the stearing wheel
it is on a 1995 4runner sr5 4x4 22re
Old Apr 9, 2005 | 03:13 PM
Gangus2006's Avatar
Is the vehicle a manual?
Old Apr 9, 2005 | 03:18 PM
shizfu's Avatar
yes 5 speed
Old Apr 9, 2005 | 03:35 PM
fadetoblack72's Avatar
It should be the safety overide. Turn your key to the on position and push it. the vehicle will start with the clutch NOT depressed, whether it is in gear or not. Be careful!!!
Old Apr 9, 2005 | 03:47 PM
waskillywabbit's Avatar
It is the driver seat ejector button! OR the clutch cancel switch....
Old Apr 9, 2005 | 03:52 PM
shizfu's Avatar
hehe i didnt fly out when i tried it but it doesnt start unless the clutch is pressed i tried. the light goes on when the ignition is on and unable to turn the light off till i turn the ignition off.
Old Apr 9, 2005 | 06:06 PM
Gangus2006's Avatar
Im positive its the Clutch Cancel Switch (CCS). Insert key, turn to on, press that button, and start...
ONLY do that if you are absolutely positive that your truck is not in gear, and the e-brake is on..
Old Apr 9, 2005 | 08:36 PM
Yamaha+Toyota=Fun's Avatar
Not true, you can accually use it to drive your truck a short distance. Put you truck in gear, press the CCS and turn the motor over. Can be helpful in some situations....
Old Apr 11, 2005 | 09:01 AM
shizfu's Avatar
thanks everyone it is a clutch cancel switch. I wasnt holding down the button while i turn the key. thanks again
Old Apr 11, 2005 | 09:12 AM
ken.vs.ryu's Avatar
yes this is what i did to get me to the mechanic when they replaced the clutch master cylinder. saved me at least $200!
kawazx636
Oct 6, 2021 03:03 PM
beltcutter
Sep 30, 2015 06:14 AM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
