supercharger help
Old Feb 11, 2005 | 05:56 PM
HOJU's Avatar
supercharger help
I need a little help with something, On the back of the supercharger (side that faces the firewall) there are two holes that i believe should be plugged, but are not, what do i do? my camera is broken, but here's a picture that shows where they are, mine is a little different than this, but you get the idea. i can see into the charger, and nothing in the instructions seems to show anything that might go there....
little help?
Old Feb 11, 2005 | 10:49 PM
HOJU's Avatar
nobody has any ideas?
Old Feb 11, 2005 | 10:55 PM
superjoe83's Avatar
maybe some plugs similar to a core plug on a block?, do you have a pic without the red dots
Old Feb 11, 2005 | 10:59 PM
4-RUNNIN' FREAK's Avatar
Going to look at mine real fast.
Old Feb 11, 2005 | 11:06 PM
N/M. Can't see behind it.
In this pic from WWW.GADGETONLINE.COM <---good help site
Is it the gold colored part you are referring to? Or the smaller "holes"?
Old Feb 12, 2005 | 05:35 AM
HOJU's Avatar
yeah, the picture looks like it's a copper plug? almost like a freeze plug.... i'm heading to the dealer this morning, but i highly doubt that they've just got those sitting around
Old Feb 12, 2005 | 11:14 AM
Gadget's Avatar
There is a freeze type plug that should be plugging the hole where the machined part is. That red dot on the right, are you saying you also have a real big hole there? That is not on any supercharger I have ever seen.
Is this supercharger on your truck? Why are those holes there? Did someone mess with it, screw it up and then unloaded it on EBay or something?
Gadget
Old Feb 12, 2005 | 11:25 AM
Troymm's Avatar
No holes in mine.
Old Feb 12, 2005 | 06:39 PM
HOJU's Avatar
well, solved the problem, just needed some freeze plugs....
Gadget I have two freeze plugs on mine, the one on display at the dealer also has two freeze plugs. one in the intake chamber, the left one. and one in the chamber after the impalers. it's machined in both areas.
Old Feb 12, 2005 | 07:26 PM
SLC Punk's Avatar
Like I said on the phone, I am glad you found some plugs! Where did you get them?
Now get out there and test that S/C out!
Old Feb 13, 2005 | 05:01 AM
HOJU's Avatar
Travis- I got them at a car quest, they were $3 each i think...
don't you worry, I'll go through a couple tanks of gas in the next day or two!
Old Feb 13, 2005 | 06:38 AM
FilthyRich's Avatar
good to hear you got it all worked out. time for crappy gas mileage LOL
Old Feb 13, 2005 | 06:47 AM
HOJU's Avatar
giddy up!
Old Feb 13, 2005 | 11:17 AM
Gadget's Avatar
I just got back from tuning a truck that had a 2nd gen supercharger on it and it had the two freeze plugs in the back unlike the picture on my site.
Gadget
Old Feb 13, 2005 | 11:19 AM
Gadget's Avatar
Where did you get this supercharger from?
Gadget
Old Feb 13, 2005 | 02:51 PM
HOJU's Avatar
Gadget, I got it from a friend locally that had it for 6 months and never put it on, but he got it from a dealer. so if you've never seen one until recently does that mean there's a new edition to the 2nd gen superchargers? And just a side question for you, how do you change the oil for the nose pulley? do you have to take it completely off?
Old Feb 13, 2005 | 05:32 PM
Gadget's Avatar
If that supercharger has never been installed, then why do you want to change the oil in the nose drive?
Do it before you install it. Call Magnuson and ask them how much oil it takes. The gray ones take 150 ml. Once you find out go to your local GM dealer and get enough bottles of supercharger oil to meet that amount. Mine takes 150 ml which is just shy of 5 oz of oil.
Use a suction device and remove all the oil from the nose drive. Once you are sure you all the old oil out then put in the new and you are done.
The easiest way to do this is just remove the nose drive. Clean it up, reseal and install it, then put in the new oil.
There are some how to guides for installing a new nose drive on the TRD website. Check them out to see what you are getting into.
Gadget
Old Feb 13, 2005 | 06:25 PM
HOJU's Avatar
Gadget, I just looked at it and thought other than taking the nose drive off, how else would you do it..... just was curious, so i thought i'd ask the master-
thanks
Old Feb 13, 2005 | 07:48 PM
turboale's Avatar
How often are you suppose to change it?
Steven.m.paulk
Jun 7, 2020 10:45 AM
LCE_Performance
Oct 1, 2015 01:03 PM
anniesball
10
Sep 15, 2015 05:41 PM
anniesball
Sep 9, 2015 09:55 AM
anniesball
Sep 7, 2015 11:20 AM
