struts please help... PLEASE~!
Old Aug 11, 2005 | 04:07 PM
TX_994x4limited's Avatar
i switched out the front shocks/struts with new ones and i have a heavy steer wheel vibration at 68mph... what could be wrong?? plus my driver side wheelspace=space between wheel and body is still lower than others.. about inch lower... what could be it?? i also change the front pads/rotors.. please help me..
Old Aug 11, 2005 | 04:45 PM
ASU4runner's Avatar
was the shock/strut as a whole assembly when you purchased it, or did you put the struts into the coil and put everything together piece by piece? If you put it together, the cup the spring sits in could be installed wrong. Or you might've left out a rubber piece in the top plate.. I dont know. Check and recheck everything according to the install sheet that came with the shocks.
Old Aug 11, 2005 | 04:50 PM
valkyrie610's Avatar
High speed vibes tend to point to balancing/tire problems. Are your lugs torqued (at least 83 lbft)?
Did you torque the lower shock bolt TIGHT (101 lbft)?
What else did you disassemble/reassemble?
Old Aug 11, 2005 | 06:26 PM
JimmyK's Avatar
Post pictures of both assemblies if you can that may shed some light on things.
Old Aug 11, 2005 | 09:30 PM
Adam F's Avatar
Yea definetly need pics.
Also, jack the front of the truck up, and grab the front wheels at 12 o'clock and 6 o'clock and wiggle it up and down. Do the same at 9 and 3. See if there is any play. Have a buddy look at the suspension and tie rods if you detect any play.
Old Aug 12, 2005 | 04:19 AM
yes, ive cheked everything and looks fine. im goin to the discount tires and rebalanced. hope that helps.. and what is the cheapest way that i can lift my truck?? lookin to lift about 2 or 3 inches..
Old Aug 12, 2005 | 04:25 AM
bamachem's Avatar
did you buy the coilpacks pre-assembled or did you break yours down and just replace the struts? either way, do you know FOR SURE that you put them on the correct sides? Driver Side actually ON the Driver Side? the driver side assembly is slightly longer. if you put it on the pass side, and vice-versa, you'd end up w/ about a 3/4" difference in height...
the vibration is most likely from alignment issues from the change in suspension geometry.
get the rig level, and if the vibration is still there, take it in and have them check the alignment...
Old Aug 12, 2005 | 04:34 AM
Intrepid's Avatar
There are colored dots on stock springs in the front, which color goes on which side? This would make it easier for him to figure out if he is right or not, unfortunately I don't know which is which...
Old Aug 12, 2005 | 05:00 AM
bamachem's Avatar
http://www.sonoransteel.com/front_coil-springs.html
Old Aug 12, 2005 | 10:07 AM
just now.. i did alighment/balancing and recheck all the hardware.. and NOTHING IS WRONG... but it seems like two front springs are exactly the same...
aowRS
Sep 13, 2017 08:22 AM
potatopants
Sep 15, 2015 06:26 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
ripp96
Jul 31, 2015 11:14 AM
wvuviv30
19
Sep 9, 2004 04:52 PM
