Stereo options: aux input or aftermarket?
Old Dec 17, 2010 | 03:59 AM
  #41
jrm's Avatar
jrm
Red face Scion T1807 SSP Function
I stand corrected. By holding the SSP button and changing the vehicle type your only changing the distribution of the sound to the size of the interior of the vehicle and NOT the EQ.
To change the EQ settings is another step. Press the SSP button, the display will will read "SSP Neutral" which is the EQ default setting. Now press the SSP button once more and the display will read "SSP Hear" and if you do it one more time the display will read "SSP Feel". The "SSP Hear" increases the bass and treble and the "SSP Feel" setting increases the bass and midrange.
The manual outlines the process.
http://tijil.org/Scion_Docs/2006_07_...udioManual.pdf
IMO The "SSP Feel" setting is the best. i cant beleive what an improvement this is. Also thanks for the pics, instructions and support from everyone. it sure made the install very easy.
Old Dec 20, 2010 | 08:15 PM
  #42
SharpStick's Avatar
Hey hey hey.
There is a thread out there (somewhere) that describes how to wire an iPod jack straight into one of the AUX jacks on the back of the Scion head units... Damned if I could find it, though. It might be on the Rav4 forum or the Celica forum.
Homemade and cheap is always nice.
STICK
Old Dec 20, 2010 | 08:26 PM
  #43
4RUNNERTMAN's Avatar
Originally Posted by okie81
I'm wondering if I could make my ipod plug with this instead of ordering the one from ebay above?
Here is the link to the writeup for this mod. Merry Christmas
http://www.toyota-4runner.org/audio-...pic-heavy.html
Old Dec 27, 2010 | 08:03 AM
  #44
okie81's Avatar
That's for a homemade aux input for the CD changer port, I'm working with the plug for the ipod port. From what I've read, it looks like a PITA to do; the pin-outs for the standard 30 pin ipod dock doesn't match up well with the harness. Also, the ipod harness (above) has insulated and non-insulated wiring which I assume is to minimize feedback into the speakers. It may just be easier to buy the $20 ebay wire.
Anyone here tried the homemade aux input? I'm curious how well it works.
Old Jan 18, 2011 | 05:21 PM
  #45
okie81's Avatar
I installed the Scion ipod cable from Ebay. It plugged right into the back of the scion headunit with no problem.
For lack of a place, I routed it under the center console and up through the emergency brake.
Plugged it in, hit AUX and it works beautifully!
One caveat:
No Charging
Old Jan 19, 2011 | 06:57 AM
  #46
jrm's Avatar
jrm
In Aux mode
Are the HU sound levels close to that of the CD player and tuner or do you have to increase the ipod volume level to get the same levels as the tuner or CD?
I've heard it mentioned that when your compressing that much sound into such a small connection that, that is why the volume levels are so different between the ipod, tuner and CD player.
Old Jan 19, 2011 | 08:04 AM
  #47
okie81's Avatar
That's what makes me hesitant about a homemade AUX input coming from the CD changer port. A lot of people say that about the volume out with that option.
Sound is excellent though, it comes out at the same volume as the radio and CD player (no adjustments needed at the ipod/iphone). It's nice to plug it in and control everything from the radio as well.
Old Jan 19, 2011 | 10:02 AM
  #48
jrm's Avatar
jrm
Thats what i wanted to hear
about using the Aux port instead of the CD changer. Thats the cable that you linked to your post on 12/14/10 right?. Im trying to warranty my GROM unit or maybe theyll let me upgrade the adapter.
Old Jan 20, 2011 | 11:40 AM
  #49
okie81's Avatar
Yeah, same cable. Just to clarify, the cable DOES give you ipod control from the headunit.
Keep us posted on your GROM warranty status, a lot of people here use those.
Old Jan 23, 2011 | 08:48 AM
  #50
jrm's Avatar
jrm
Goodbye GROM adapter
Goodbye T1807. Found a T1808 on CL for $60. Installed it yesterday. Ordered that $20 eBay cable. Oh and i read that a little nail polish remover will remove "SCION" from the face plate w/o scuffing.
<img src=http://t0.gstatic.com/images?q=tbn:ANd9GcRmn3AuMcwSh7OjADW98KJxeMFmI2kxt HD3EiUeA2J1IfW7P1U9oA&t=1>
Old Jan 23, 2011 | 08:44 PM
  #51
okie81's Avatar
Sweet find! I think you'll be happy with the ipod cable.
I found this out today: the cable will charge an ipod, but NOT an iphone
Old Mar 24, 2011 | 07:24 AM
  #52
okie81's Avatar
Thumbs up
So my original intent, if you'll recall, was to have an aux input so that I can play my ipod and provide some more clarity to my Sirius reciever (which is currently using a FM direct adapter). The Scion radio and ipod adapter solved half the problem but I was still stuck with FM quality Sirius.
Solution? Sirius app for Iphone:
The sound is immaculate (way better than the FM direct adapter or modulator). My only grip is that the extensive amount of 3G streaming really drains the battery.
Problem Solved.
Old Mar 24, 2011 | 02:20 PM
  #53
jrm's Avatar
jrm
Does the iphone charge
when your using siruis?
Old Mar 24, 2011 | 03:52 PM
  #54
okie81's Avatar
No.
Gonna pickup one of these though:
New ipods/iphones require a 5v charger, this is just a converter
kawazx636
Oct 6, 2021 03:03 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Shagool22
Sep 28, 2015 07:53 PM
Project90
Sep 24, 2015 11:40 PM
