starting issues
Old Jun 5, 2012 | 02:45 PM
docktortal33's Avatar
starting issues
hi guys any input on what might be causing my 99 4 runner not starting .the problem is turnning the key nothing happens ,but if i wiggle the automatic shifter she will start sometimes have to wiggle it alot or move the shifter from park to reverse any ideas would be welcomed thanks Doug
Old Jun 5, 2012 | 03:39 PM
RAD4Runner's Avatar
Neutral Safety Switch?
Originally Posted by docktortal33
...if i wiggle the automatic shifter she will start sometimes have to wiggle it alot or move the shifter from park to reverse any ideas would be welcomed thanks Doug
Check your schematic (link on my sig). Auto transmission should have a neutral safety switch somewhere. Just like the clutch safety switch on MT's, it prevents one from starting while tranny is in gear. Check its mounting and contacts.
Best of luck.
Old Jun 5, 2012 | 05:18 PM
ncsugrad2006's Avatar
Best of luck.
Yup. I had the same happen on a Lincoln LS once--I had to always push forward on the shifter before it would start.
Just needed a little adjusting. Yours may need a new safety switch
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Avenged
Jul 9, 2015 07:55 AM
