Starter contact selenoids part #
Old Apr 23, 2004 | 07:58 AM
phishtaco's Avatar
I read HaveBlue's write up on the starter removal/install......
I just need to know if anyone has a part # for the contact rebuild kit or starter kit that includes the 2 new contacts. My local dealership was no help "You gotta buy the whole assembly for $230."
Old Apr 23, 2004 | 08:01 AM
DaveKerwin's Avatar
http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
Old Apr 23, 2004 | 09:06 AM
phishtaco's Avatar
Thanks, but which ones?
Old Apr 23, 2004 | 09:17 AM
DaveKerwin's Avatar
Read the link!!
"Which type should I order?
The Type-A contact should fit in almost all starter solenoids
It can also replace a Type-B or Type-C contact, only difference is a bit smaller contact surface area
The Type-B or C contact will fit the battery side on the newer Toyota engines/starters
If in doubt, get one of each and you can return the unused contacts for credit (US$4.00/ea. to your PayPal account)
You may even be able to upgrade a smaller contact with a larger one if it physically fits
The larger contacts have about 50% more copper in contact with the solenoid plunger, so should last longer
Best bet is to open up the solenoid in the starter and have a look at the contacts. This way you'll know for sure if the contacts are worn and if so how many and which type you'll need. "
Old Apr 23, 2004 | 10:24 AM
phishtaco's Avatar
Originally Posted by DaveKerwin
Read the link!!
I have read the link before!!!
Just seeing if anyone actually knows which ones
Old Apr 23, 2004 | 01:23 PM
DaveKerwin's Avatar
when you take the starter apart, match it to the picture I posted, or buy all of them for 20 bucks and send the unused ones back for a refund.
Or pay the dealer.
Old Oct 17, 2004 | 06:12 PM
Cebby's Avatar
My starter on my 93 4Runner with 3.0 had two contacts that looked like "A". The replacements supplied by Toyota were an "A" and a "D". I put the "D" on the side that gets the most wear.
Here's a couple of pics:
And one of my little helper bolting the access panel back in. He just turned 6. The red between his legs is the jackstand. Safety first...
Old Oct 17, 2004 | 06:37 PM
PutzRunner's Avatar
For my 1997 4Runner the contact part numbers were:
28226-54340 And 28226-72010
Hope this helps.
Old Oct 17, 2004 | 06:56 PM
Adam F's Avatar
See my writeup here
http://www.toyotaoffroad.net/afertig...rterrepair.htm
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
thefishguy77
Jul 30, 2015 10:59 AM
ZONAYODA
Jul 13, 2015 07:17 PM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
