Started headgasket replacement......NEED HELP
Old Feb 23, 2004 | 04:18 PM
mattk's Avatar
Ok guys started my head gasket replacement on my'95 Runner. Got everything off except the exhaust manifolds. Thats the only thing holding me up. Is there a trick to getting to all the nuts on those things cuz i cant even get to all of them to get them off. Looks to me like removing the motor.....which i dont wanna do.......would help. Does anyone have any tips for me? Any help would be greatly appreciated!
Old Feb 23, 2004 | 04:26 PM
AverysDad's Avatar
are they stuck or can you just not reach them?
Old Feb 23, 2004 | 04:41 PM
mattk's Avatar
I cant even get to them..........i can get to a couple of them but after that there isnt any room whatsoever to get anything in there to get them off
Old Feb 23, 2004 | 04:56 PM
AgRunner06's Avatar
One word: swivel.
That's the only thing I can think of. But then you have the problem of putting them back on.
Old Feb 23, 2004 | 05:03 PM
934rnr's Avatar
Originally Posted by AgRunner06
One word: swivel.
Use a long 14MM with a extendsion. Also if your exhaust studs have the star shaped end you can use a torx socket to remove those it makes it alot easier to just remove the exhaust studs to pull the head. Believe me I have done the head gaskets on a 3VZE 2x's now.
Old Feb 23, 2004 | 05:20 PM
mattk's Avatar
I can get to the right side bolts....at least the ones up top but what about the ones below that i cant even see. on the right side the steering rod is in the way and on the left side theres all kinds of junk in the way. Any suggestions?
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
