slight electrical problem
Old Mar 2, 2009 | 09:25 PM
Elton's Avatar
i got some new led blinker bulbs ... and deiced to clean up my wiring a little and i accidentally touch the hot and ground together and blew the fuse ... so after i got the bulbs and load resistors installed ..... i replaced the fuse and now the hazard lights don't work and when i press the on the brake pedal the buzzer goes off
Old Mar 2, 2009 | 09:53 PM
1989toy4wd's Avatar
Did you check all the fuses??
It sounds like a short somewhere for the brake/buzzer, but the hazards sounds like a fuse!!
Worst case senario...Body control module, but if that went out, a bunch of other stuff wouldnt work either!!!
Im sure you did check all the fuses...then its time to get the good old DVOM out and do some testing. When you say you accidentally touched the hot and ground, do you mean the battery?? if so was it hooked up?
Old Mar 2, 2009 | 09:54 PM
Elton's Avatar
all fuse are good and i mean the turn signal wires its self guess ill have to tear everything apart and recheck the wiring again
Old Mar 2, 2009 | 09:58 PM
1989toy4wd's Avatar
Look at the grounds first...do you have a haynes manual or something to look at?? I am willing to bet that those things all share the same ground.
Old Mar 2, 2009 | 10:00 PM
stormin94's Avatar
Could you have possibly fried a relay?
Old Mar 2, 2009 | 10:03 PM
1989toy4wd's Avatar
No, I dont think a relay would have done this, I mean its possible...but unlikely
Old Mar 2, 2009 | 10:13 PM
Elton's Avatar
im thinking it maybe the relay cause it was all working fine tell i grounded it and blew the fuse
Old Mar 2, 2009 | 10:21 PM
1989toy4wd's Avatar
yeah, but do all those things go through the same relay? The reason I am saying that is the buzzer/pedal situation. It just doesnt sound like a relay problem...but I can tell you how to check a relay, if you want??
Old Mar 2, 2009 | 10:27 PM
scuba's Avatar
K elton, On my 99 taco FSM, this might not be exact but on the inside fuse panel, right under the fuses there should be a couple relays, one is a "Flasher relay" I would replace that fuse as my next move
Old Mar 2, 2009 | 10:31 PM
1989toy4wd's Avatar
Oh, did you take out and look at all the fuses or did you just glance at them when they are plugged in? Cause sometimes they blow, and you cant see it!
Old Mar 2, 2009 | 11:21 PM
Elton's Avatar
i did take out the ones i thought they be
Old Mar 2, 2009 | 11:49 PM
scuba's Avatar
You did read my post...Yes ?
Old Mar 3, 2009 | 08:34 PM
Elton's Avatar
i feel like i wasted your time lol... anyways i went to use my horn today ehh its not working so i checked the fuse sure enough it was popped so i replaced it and now the hazards work who would of guess there tied into the horn wireing .... and i believe i have the warning buzzard solved too when i press on the brakes the front corner lights come on soo ill have to tie the resistor into that since there led too
Old Mar 3, 2009 | 08:54 PM
scuba's Avatar
Well glad you got it figgured out
Old Mar 3, 2009 | 08:59 PM
Elton's Avatar
lol i just find it odd how the wireing is set up
Old Mar 3, 2009 | 09:12 PM
scuba's Avatar
Yeah my freakin fuel gauge is constantly on, I think its due to a crappily set up viper alarm, so ima look at that soon, Gotta do my starter contacts first...
Old Mar 4, 2009 | 09:27 PM
Elton's Avatar
well once again i make a thread for nothing ive solved everything not sure what happen but theres something wrong with the led bulbs for the brake lights ill just buy some new ones later
Old Mar 6, 2009 | 06:00 PM
stormin94's Avatar
I would hope your fuel gauge is constantly on.
coryc85
Sep 9, 2015 06:24 AM
thefishguy77
Jul 30, 2015 10:59 AM
Yota.Jay
Jul 23, 2015 08:08 PM
v_man
Jul 23, 2015 04:01 PM
AaronM
Jul 8, 2015 07:15 PM
