Sirius Satellite radio mounting suggestions needed
Old Dec 26, 2003 | 03:15 AM
Runner4's Avatar
Well the wife came through and got me the Audiovox Sirius Shuttle (Satellite Radio System) for the 4Runner. I spend 3+ hours a day in the truck so this will be a wonderful gift. Anyone else have the Audiovox Shuttle? I'm looking for some mounting ideas. There's really no good place to mount it, and wherever I decide to put it will need some custom mounts made. Any ideas? The shuttle is about 4.5" Wide, 3" Tall and 1.75" Deep.
Old Dec 26, 2003 | 03:24 AM
SLC Punk's Avatar
If you don't use your ash tray, then mount it in that pocket under it.
Old Dec 26, 2003 | 03:28 AM
Runner4's Avatar
That's where I'm thinking too. I just need to figure out a way to make a bracket that I can mount inside the pocket. That way, I don't have to drill holes in the console around the gear shifter.
Old Dec 26, 2003 | 03:31 AM
SLC Punk's Avatar
Go to home depot and look for some "L" brackets, then you can glue of mount it to the panel.
Old Dec 26, 2003 | 04:42 AM
shazaam's Avatar
my set up
This is what I did with mine .... hope it helps.
EDIT: someone please let me know if the link works, I can never get it to work right.
Old Dec 26, 2003 | 04:51 AM
Runner4's Avatar
Originally posted by sdastg1
my set up
You definately have a nice setup - very clean, custom install. Mine is a bit different especially in shape and size. This is the one I have (with the car kit):
Sirius Audiovox SIR-CK1 Shuttle
Old Dec 26, 2003 | 05:08 AM
shazaam's Avatar
sorry I thought it was the same kenwood as mine, didn't pay attention to the model number.
The only suggestion I have for you is mount it at eye level, or at an angle where you can read the screen easily. Also a place where you can easily reach the buttons, b/c those things are so damn small.
Other then that, take pics and show us what it looks like
EDIT: I just noticed your in chicagoland, where abouts?
Old Dec 26, 2003 | 05:14 AM
Runner4's Avatar
I live in Lockport and work in Naperville. How 'bout you?
Old Dec 26, 2003 | 05:15 AM
SLC Punk's Avatar
my set up
Can you see out of the rear view mirror with the PNP there?
Old Dec 26, 2003 | 05:17 AM
Runner4's Avatar
SLC Punk:
I noticed a post of yours on the backstage Sirius forum where you posted a pic of your roof mount antenna. I was thinking of putting the antenna in the same place originally, but I could'nt get the wire to fit snug enough to stay in place. It seems that there was too much space around the window. How did you get your wire to stay put?
Old Dec 26, 2003 | 05:35 AM
Runner4's Avatar
SLC Punk:
How did you run your power? What did you tap into? Did you buy an aftermarket adapter wire? Did you use an in-line fuse?
Old Dec 26, 2003 | 05:38 AM
shazaam's Avatar
No problems with the rear view mirror, from the angle I took the pic it seems like it blocks the view, but when I'm driving I have no problems.
runner4: I used to live on N. Lake Shore Dr., I just moved about a month and half ago to Md.
Old Dec 26, 2003 | 05:50 AM
paxam's Avatar
mine is built into the radio and the reciever box is under the dash. I mounted the ant on the dash . it works pretty good. I had it on the outside but the truck looked realy bad.
Old Dec 26, 2003 | 05:54 AM
Runner4's Avatar
SLC Punk:
Old Dec 26, 2003 | 05:57 AM
SLC Punk's Avatar
Originally posted by Runner4
SLC Punk:
If you look at your window molding. The gap (like you described), if you look behind it, you will see where the rubber meets the body. I took a real small screwdriver and small pocket knife and pushed the seal out enough to get the wire below it. Then make sure that the seal doesn't fold.
Probably doesn't make sense, but if you look at your window molding you will understand.
Old Dec 26, 2003 | 05:58 AM
SLC Punk's Avatar
SLC Punk:
I already had a wire to tap into from a previous failed mod (outside temp gauge)
I used one of those fuse tap's and have it fused through there.
Old Dec 26, 2003 | 06:28 AM
Runner4's Avatar
I'll have to look at the windshield. Right now my antenna is on the rear roof, and comes in through the rear hatch. I'd rather move it to the front. Thanks.
Old Dec 26, 2003 | 06:39 AM
SLC Punk's Avatar
I installed it that way at first. But when I opened my rear hatch all the way, the hatch was pressing on the cable. I was afraid that it would short it out. So that's why I moved it to the front.
Do you have the Terk 3 antenna?
Old Dec 26, 2003 | 06:46 AM
Runner4's Avatar
Yes, I have the Terk3, but the wire doesn't seem to be getting pressed when the hatch is fully open. I would still rather have it in the front anyways.
Old Dec 26, 2003 | 08:32 AM
midiwall's Avatar
Runner4;
I have the Delphi receiver for XM radio which is about the same shape/size of the Shuttle. I don't have a dedicated picture of where it ended up, but you can see it in this shot:
http://www.midiwall.com/4Runner/dirt..._Reiter_13.jpg
Basically, it's sitting just in front of the transfer case lever.
