Simple Horn Mod
Old May 9, 2004 | 06:37 PM
  #101
Scofco's Avatar
Oh, and don't slip and let the + and - wires touch the body. ZAP!
I had to get a new fuse because of that. The guy at the gas station gave me a new one for free though
Old May 9, 2004 | 08:05 PM
  #102
SkyRat's Avatar
Disconnect the battery whenever you work on your electircal system. It could save you big bucks down the line.
Old May 9, 2004 | 08:10 PM
  #103
Scofco's Avatar
I'll keep that in mind when I install the 2nd horn
Thanks for the tip.
Old May 10, 2004 | 02:12 PM
  #104
98 Joes's Avatar
I replaced my wimpy sounding horns today with the same Fiamm Freeway Blasters. Only 30 minutes to do the whole thing and what a difference it makes. No more sounding like a motorcycle. Nice thing was I didn't even have to cut any wires. The plug on the factory wires plugged in perfectly. They are actually a female spade connector in a fancy little plug.
Anyway, thanks for the writeup.
Old May 10, 2004 | 02:18 PM
  #105
Waterboy's Avatar
Originally Posted by Scofco
They hold up to mud well. Hyuk.
I've had to replace a few because they crapped out after filling up with water or mud. Mine is messed up again right now but I haven't replaced them yet. I was able to clean them out one time when they filed with mud but everytime after that I've had to replace them because they don't work after a swim.
And what the crap is Hyuk?
Old May 10, 2004 | 02:23 PM
  #106
SkyRat's Avatar
Do you have em mounted with the openings facing down?
  #107
98 Joes's Avatar
If you're having problems with stuff getting in the trumpet of the horns, Cover them with something. Two things I've used on other things I wanted to keep dirt out of was a piece of screen door material and even better was piece of old pantyhose. It was easy to work with and conformed to odd shapes well. It wonn't stop a water drenching, but it helps and it keeps mud, dirt, bugs and small children out.
Old May 10, 2004 | 02:43 PM
  #108
Waterboy's Avatar
The first time I had them aimed at each other other because I thought they would sound better that way. When they were aimed that way I was able to clean them out after dunking them but since I've had them pointed down they die when ever they fill up.
I've decided then next time I pull them off to clean or replace I'm going to put them under the hood, I'll loose some of the volume with them in there but I think they'll last a little longer that way.
I've considered putting plastic bags over them when I go out but the pantyhose idea sounds like a good one for the mud.
Old May 10, 2004 | 05:43 PM
  #109
4RUNR's Avatar
Guest
Anybody notice how air horns get much quieter on warm humid days?
There's this empty stretch of road with woods on either side that I pass every day and honk slightly there to give the compressors a workout. On cold dry days there's an echo for a few seconds, on humid no echo at all
Old May 10, 2004 | 05:52 PM
  #110
4RUNR's Avatar
Guest
This paper presents, expands, and clarifies the en-
vironmental effects of temperature and humidity on the
speed of sound. These effects increase the speed of
sound and complicate the task of room equalization im-
mensely? much more so than previously thought.
The dramatic effect of relative humidity on sound
absorption appears as a separate section and helps ex-
plain many mysteries involving startling changes in
room response from day to day. Even a modest change
in relative humidity of only 10% can cause an additional 35 dB per 1000 ft (300 m) of absorption.
Well that explains it.
Old Oct 23, 2004 | 05:46 PM
  #111
Jared Ajlouny's Avatar
i really need a new horn. i was looking at harbor frieght and cannot decide between these two (will either of these work?).
http://www.harborfreight.com/cpi/cta...emnumber=44760
http://www.harborfreight.com/cpi/cta...emnumber=40135
thanks guys
Old Oct 23, 2004 | 07:32 PM
  #112
fromjeeptotoyota's Avatar
you guys want amazing horns you have got ot try these hella horns
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
thanks guys
Old Oct 23, 2004 | 09:12 PM
  #113
its 4 times as much as the other one, and its bassicly the same thing!
Old Oct 24, 2004 | 12:03 AM
  #114
SkyRat's Avatar
Jared
These are what I used in the original write-up.
Fiaam Low and the Fiaam High Note you listed above. One of each.
They are cheap, work great and are a no brainer to install.
Old Oct 24, 2004 | 07:44 AM
  #115
Jared
thanks man, i was looking for those but couldnt find them. harbor friegh sucks how they try to charge you a handleing charge and dont even tell you about it till after you order!!!! :pat: shipping was 4 dollars..the hidden handleing...6 bucks!!!!
Old Oct 28, 2004 | 08:31 PM
  #116
i got them in the mail today and i went outside to go install them and on mine there is only 1 stock horn!! how am i going to do thi snow, do i run a wore formt he stock power wire to the other horn? anyone know???
Old Oct 29, 2004 | 03:17 AM
  #117
Corey's Avatar
Co-Founder/Administrator
Run the power wire from the first horn to the 2nd one, and the ground.
Prepare to blow thy neighbors away with the tooooooooooooot
Those are the horns I have.
Old Oct 29, 2004 | 05:52 AM
  #118
wont the horn be half as powerful that way????? and i have to do this for both the positive and ground????
Old Oct 29, 2004 | 03:47 PM
  #119
Corey's Avatar
Do diff in power.
That is how mine are hooked up to one power and ground I believe.
Old Oct 29, 2004 | 08:11 PM
  #120
Do diff in power.
hoocked them up...PAIN in the @ss but i got them working...thanks for the advice!
