should there be any play in driveshaft?
I have horrid noises coming out from under my truck. Got under it today and there is some play in the driveshaft, at the yokes.
couple stupid questions:
Should there be 0 play, or some?
Are yokes the same as U-joints?
what is the risk in driving the car with WORN bearings/joints?
If I grab the shaft and try to move it back and forth quickly, I can hear a sound in the 3rd - almost like gear teeth having a slight amount of space between them before they actually touch. I am hoping this is normal.
Put it in neutral and grab the driveshaft with one hand and grab the piece where it bolts next to the transfer case and rotate. see if there is play right at the ujoint. do the same for the ujoint next to the 3rd member.
kawazx636
Oct 6, 2021 03:03 PM
zytra
Jan 24, 2019 03:16 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
