Shock bolt help
Old Jul 3, 2003 | 04:31 AM
metal22lica's Avatar
Shock bolt help
ok guys..last night i attempted to change my coils out. i got one out..and i went to put the shock back on. i had no problems with the bottom bolt...but the top bolt and nut just keeps on spinning and wont tighten..any ideas on how to tighten it?
Old Jul 3, 2003 | 05:12 AM
TDiddy's Avatar
Can you get the nut started with your fingers?
Once you get that far, put a wratchet up there and let it push against the shock mount. Then you can turn the shock by hand from below to tighten it, and the wrachet braced against the mount will hold the nut still for you.
Old Jul 3, 2003 | 05:30 AM
yeah..i got the nut on it and started a little.
Old Jul 3, 2003 | 01:09 PM
NCSU-4runner's Avatar
the shaft of the shock is twisting, get a set of vice grips on it and the nut on the top with tighten down real easy.
are they stock shocks, with the retarded shroud around the top? when i took my stock shocks out i had to bend the outer shoud so i could hold onto it to get the nut off the top end. i was installing new ones tho so i didnt care.
Old Jul 3, 2003 | 05:25 PM
Gadget's Avatar
I don't know what kind of shock you are installing, but if you put vice grips on the piston rod shaft and nick the crome it will need to be replaced very soon afterward.
I do have one tip for you. Make real sure you lather up that threaded part with plenty of antiseize compound. That will prevent corrosion and make it much easier to take off the next time.
Gadget
www.GadgetOnline.com
Old Jul 3, 2003 | 06:09 PM
i had to vice grip my doestch rear shocks to get the top nut in, its been three months and no sign of rusts. im fairly sure the shafts are stainless
Blamalam
Mar 12, 2022 07:34 AM
Braparus
42
Jun 30, 2016 12:17 PM
justdifferentials
Sep 8, 2015 03:13 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
SMOD
Jul 27, 2015 01:45 PM
