SHHH noise from engine with quick accel.?
Old Mar 16, 2009 | 12:18 PM
surfh2o's Avatar
When I do a quick blast with the accelerator I hear a somewhat loud shhhh like a blast of compressed air in the engine block. Under normal acceleration it seems fine. It's when I hit the gas quick it kinda stutters and then the gas kicks in and when I do it even faster is when I hear the air sound. Thinking maybe fuel filter or injectors, but not really sure. Any ideas?
Old Mar 16, 2009 | 03:32 PM
raydouble's Avatar
I would check all vacuum lines under the hood (there aren't that many) from the diagram under the hood.
Maybe someone else will have some suggestions........
You don't have a supercharger do you?
Old Mar 17, 2009 | 04:21 AM
surfh2o's Avatar
No charger. I'll have to check the vac lines. Thanks
Old Mar 17, 2009 | 06:15 AM
annoyingrob's Avatar
Mine does that........
But it's the turbo
Old Mar 19, 2009 | 08:15 AM
j-man's Avatar
mine too - gotta love that BOV... everything should have a turbo, plain and simple...
Old Mar 19, 2009 | 09:04 AM
I agree.
Old Mar 21, 2009 | 06:22 AM
97ltd4x4's Avatar
possible vacuum leak,but you would also have an abnormal high idle speed as well...
Check your intake boot(between MAF and throttlebody) very closely for cracks and loose clamps..take it off and inspect for cracks if you have to....when you accel the torque of the engine can possibly be pulling and opening up a crack in the intake boot? Its a guess...
Old Mar 21, 2009 | 07:13 AM
TNRabbit's Avatar
Not necessarily; many compensate for a vacuum-induced high idle by reducing the idle...
It could also be an intake crack, but you'd probably have a miss associated with that. Did you add a ricer intake lately??
Old Mar 21, 2009 | 07:51 AM
97ltd4x4's Avatar
start pulling vacuum lines on the 5VZ and let me know which one's reduce the idle speed...........
Old Mar 22, 2009 | 05:46 AM
surfh2o's Avatar
It actually seems to idle low. Like maybe 500. I need a chance to check all these things. To be continued. Thanks
Old Mar 22, 2009 | 06:17 AM
mt_goat's Avatar
Might be an exhaust leak.
Old Mar 22, 2009 | 06:34 AM
MillerPKA's Avatar
check both ends of the pcv line and the hose's integrity
Colington
Mar 8, 2020 09:51 AM
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
