Runner won't idle
Old Sep 29, 2003 | 06:13 PM
PutzRunner's Avatar
Runner won't idle
Well I am scratching my head. I have a stock 97 3.4L 4runner and it goes dead at idle. I have cleaned the throttle body, there is no "check engine" light. Alternator checked good along with the battery. I had the codes checked at a garage and there are no codes. I have checked the throttle position switch with a volt/ohm meter and checks good.
I am still scratching my head.
I just finished a great day 4wheeling in the mountains and I stop at a stop sign in town and it goes dead. Then it dies at every stop. It will start but only after turning it over quite a bit.
I have done a search, but no help so far.
Any ideas would be greatly appreciated.
Old Sep 29, 2003 | 06:14 PM
Victor's Avatar
Check your intake hose for tears/holes. If there is any air getting in past the MAF you will lean out and the engine will not idle.
Old Sep 29, 2003 | 06:23 PM
Unhappy99's Avatar
Clean the MAF and IAT module.
Old Sep 29, 2003 | 06:34 PM
PutzRunner's Avatar
Thanks guys, for the suggestions. I will try these and see
where I am.
I am also open for more suggestions.
Mucho Appreciato
Old Sep 29, 2003 | 06:51 PM
AznSky's Avatar
yea kinda sounds like a maf or air intake related problem.
Old Sep 30, 2003 | 06:59 PM
PutzRunner's Avatar
Well it is fixed. The pulley on the crank shaft was
loose and the sensor could not get a good reading
on the cranl pulley.
But it i idling fine and running great. Thanks for all
the input on the problem.
Old Oct 1, 2003 | 04:57 AM
Victor's Avatar
Hadn't even thought of that. Makes sense since you don't have a distributor the ECM needs that crank position sensor to set the ignition advance and fuel injection.
Old Oct 1, 2003 | 10:44 AM
PutzRunner's Avatar
I discovered it by accident. I was just grabbing stuff and
wiggling it to see if anything was loose and the pulley looked suspicious.
Tightened it up with a little LockTite and it was good to go.
If anything strange will happen, it will happen to me.
Old Oct 1, 2003 | 11:06 AM
Tacoma Dude's Avatar
That's funny cause if anything stupid is going to happen, it'll happen to me!
We must be related somehow
Old Oct 1, 2003 | 04:08 PM
PutzRunner's Avatar
This is beginning to sound like
Dumb and Dumber
Old Oct 1, 2003 | 04:32 PM
Gadget's Avatar
Have you ever had the timing belt replaced? It sounds like another improper pulley bolt installation.
That bolt needs to be torqued to 250 NM which a lot of torque. Anything less then that it can back out and if the pulley backs off of the woodruff key it can destroy the pulley and the cranksaft.
There is a special took that is needed to tighten that pulley bolt and it is almost impossible to do so without it.
Gadget
www.GadgetOnline.com
Old Oct 1, 2003 | 06:32 PM
PutzRunner's Avatar
Thanks Gadget,
I have replaced the timing belt recently. I will
check on that tomorrow and see what happens.
It is still running okay now.
Old Oct 1, 2003 | 07:32 PM
Gadget's Avatar
If you do not properly torque that pulley bolt if can cost you a crankshaft. 250 NM is a lot of torque and that is what it needs.
Gadget
Old Oct 2, 2003 | 07:19 AM
MTL_4runner's Avatar
You are gonna need at least a chain wrench (put a piece of old serpentine belt under it to prevent damage to the pulley) and a big ass breaker bar (3 ft at least) to get that bolt on there tight enuf. Like Gadget said, if you don't and it comes lose and spins inside the pulley, you will definately be out of pocket some serious $$$$$$$
Old Oct 2, 2003 | 11:23 AM
Gadget's Avatar
If it would just fall off there would not be so much damage. The other belts seem to hold the pulley from coming all the way off.
If the pulley pulls out just about 3/8" it will disengage from the woodruff key and then the crank will spin inside the pulley tearing up the pulley and the crankshaft. It is easy to replace the pulley, it is the crankshaft that gets a bit expensive.
Gadget
zd92655
Mar 6, 2022 12:58 PM
JF9243176
Oct 8, 2017 04:21 AM
Cesarl74
Apr 23, 2016 06:07 PM
Sandman
Jul 23, 2015 08:15 PM
Niameyrider
Jun 25, 2015 05:50 AM
