View Poll Results: which rotor type
blank
45
67.16%
xdrilled+slotted
22
32.84%
Voters: 67. You may not vote on this poll
Which rotors for me?
Old Apr 27, 2006 | 04:37 AM
  #41
uberhahn's Avatar
More importantly than slotting/drilling, do a search on cryo-treating them. Cryo-treating should be relatively cheap and is sometimes an option depending on where you buy them. The rotors are "frozen" for a few days near absolute zero. This changes the material density. WHY?
Proven to reduce wear on the rotor and speed heat dispersion. I have done this on my 240Z race-car among others and will do it on my DD.
Old Apr 27, 2006 | 06:38 AM
  #42
jodynich's Avatar
http://cgi.ebay.com/ebaymotors/96-02...spagenameZWDVW
is that a good idea?
Old Oct 2, 2006 | 04:37 PM
  #43
nj4runner's Avatar
interesting tread. I have also seen threads that talk about using the brakes from a tundra. what are your thoughts?
Old Oct 4, 2006 | 04:44 PM
  #44
KMoses's Avatar
Link to the tundra brake mod https://www.yotatech.com/forums/f2/big-tundra-brakes-3rd-gen-4runner-74601/ Just picked up a set of 231 calipers & waiting for my OEM Rotors (Blanks) to come in....my 97 runner rotors are new but warped - sucks!
Not trying to hijack this thread....anyone know if the 231's will fit under MT Classic II's (16 with 35/8 BS) w/o grinding ??
Old Oct 28, 2006 | 03:56 PM
  #45
FredTJ's Avatar
Solid (vented) rotors, all other things being the same, will give you the most braking power, under all conditions that we're likely to see.
Drilled and/or slotted remove mass and surface area from the rotor, both of which are detrimental to it's performance.
Your brakes (pads) will not outgas under any conditions that you'll likely to experience.
For instance, directly from Brembo:
IMPORTANT REMINDER: Slotted, drilled or dimpled rotors offered as OEM replacements should not be considered appropriate for high-speed use.
Grooved, drilled and slotted rotors offer an enhanced appearance and may add some resistance to the boundary layer of gasses that can build up between the pad and rotor under extreme conditions, they are not designed to withstand the extreme temperatures that are produced on a track.
Get qood quality CAST rotors, solids (vented), that are not crossed drilled and/or slotted, for the best braking performance.
Fred
Old Nov 14, 2006 | 05:27 PM
  #46
mikehinthehouse's Avatar
Fred
So which ones.... Im about to get new rotors due to warped stocks.... powerslots? brembo drilled? brembo solids???????
Old Nov 14, 2006 | 05:30 PM
  #47
FredTJ's Avatar
Well, obviously, solid.
Brand won't make a whole heck of a lot of difference as long as you stay away from the off shore ones.
Shop price (non-off-shore) if you wist.
Fred
Old Nov 14, 2006 | 06:01 PM
  #48
MTL_4runner's Avatar
Just a plain jane (no slots, no holes, no cryo) set of Brembo rotors will do you just fine.
They are available many places, but www.tirerack.com has pretty decent pricing online.
Old Nov 14, 2006 | 10:22 PM
  #49
91TPU's Avatar
imo i would just get blanks or if u can just slotted rotors. drilled rotors are designed for brakes that operate under very high temps, such as autocross, gp, etc. i have seen them crack in between the drills twice now on other peoples vehicles, and thus, i wound up doing brake jobs for them. i stand for blank or just slotted, no drilled, but again thats my 02 and my exp.
Old Nov 15, 2006 | 04:02 PM
  #50
right on... ordered them late last night.. Brembo solids from the tire rack... $129 and some change shipped to the door... I cant wait, no more vibrating and shaking.... now to just choose which ceramic pads.... prolly some carquest golds or blues... dunno have a few days till disc get here
ladybugRC
458
Aug 21, 2020 10:41 AM
Kamaloha
Oct 16, 2015 05:13 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Toys4parts
Sep 26, 2015 01:56 PM
