removing/installing cv axle driver side front
Old Apr 30, 2004 | 10:54 AM
dallas tacoma's Avatar
hi,
my dad's 4wd 00 tacoma front driverside axle boot is torn and needs to be replaced. i will get a whole axle from autozone or oreillys.
I have replaced axles from hondas many times but not on a toyota. i was doing a search and found out that the axle does not have a spindle nut? is this correct? i just pull this out from the hub after i get the other side out of the differential?
will this be tough to get it out of the differential? i really don't want to pay anyone to do the job. i believe i'm capable of doing it but has anyone had any problems pulling or installing one?
oh yeah, what generation would an 00 be?
thanks alot!
Old Apr 30, 2004 | 11:40 AM
Roadrunner's Avatar
Check this write-up, it should help:
Changing the CV Boots on a ADD Equipped Tacoma.
If you don't mind me asking, how much is the axle assembly you're getting from Autozone? Thanks.
Old Apr 30, 2004 | 12:43 PM
thanks for the reply...the assy is $84 after the core is returned from oreillys. lifetime warranty, not too bad.
http://www.oreillyauto.com/B2C/condi...ehicle0&page=1
my dad don't go off-road too much. so this should be okay.
Old Apr 30, 2004 | 01:12 PM
Pry off Axle nut dust cover. I used a small chisel to do this. Be careful not to damage the cover, as it will be reused.
Pull out cotter pin from axle and small nut cover.
Take off the axle nut using a 36mm socket.
Take out the four small bolts that hold the lower ball joint onto the spindle.
Slide the spindle off of the axle and out of the way.
got one question about the link. 5th instruction is to "slide the spindle off of the axle.. " is the going to need some hammering? or will it just slide off like it says and with ease?
thanks for the help!
Old Apr 30, 2004 | 01:48 PM
BajaTaco's Avatar
Contrary to what the www.ttora.com website says, I would consider the '00 taco to be 2nd gen (not 1st gen) because there was a major style change and addition of the TRD package in '98.
Anyway, to anwer your question - yes it should slip off without a hammer, but it will probably require a little bit of muscle/persuasion, but not too much. It's a pretty easy procedure.
Some things to note:
1. When you remove the 4 bolts that hold the lower control arm to the steering knuckle, they can be a pain because they have to be tight. One of them is kind of recessed into the tapped casting so the head of the bolt is a little shallow to get a socket on. I had to use an impact wrench to get one of mine off the first time. It will help to pre-soak these with some penetrant like liquid wrench. When you re-install these - be aware that some people have reported them working loose after driving the truck! I used some red loc-tite to make sure they are not going to come off and have not had any problems.
2. The big nut that has to come off (hub nut) - is most likely a 36mm. BUT, some guys (seems to be 4runners) have reported 35mm. So just be aware that there is a remote chance that you have a 35mm, but most likely a 36mm if it is a '00 Taco.
3. When you pull the CV axle out of the diff - be careful not to just grab the outboard portion of the axle or shaft and yank on it. There is nothing really holding the inner tripod joint inside of the tulip except the rubber boot - so you might damage the boot or make it leak (this isn't really an issue if you are going to junk it as a core anyway). But, what I am saying is that you can grab the tulip (solid part) of the inner joint and pull it out of the diff. When it comes out, there is a c-clip on the stub shaft that some people mess up. Since you will have a new axle - it should come with the c-clip - but make sure you have a new one in case you mess up the old one.
4. When you put the new axle into the diff - it might be a little tough to get it to pop in there. But it does kind of "pop" in there and likely will with a good push. If not, what you can do is take a large blade screwdriver or similar device and tap on the "fins" that you will see on the inner face of the tulip housing that mates up to the diff. to help it out a little.
Old May 2, 2004 | 04:59 PM
bajataco,
thanks for the extensive write! does not sound bad at all.
i'll let you know how it goes. turns out i'm going to be replacing both fronts
would you know how i can determine if mine has Automatic Differential Disconnect?
thanks a bunch!
Old May 2, 2004 | 05:17 PM
jx94148's Avatar
If it dosen't have dials on the hubs its ADD.
Old May 6, 2004 | 06:34 AM
i just checked this morning, its got the aisin dials with Free and Lock on the hub.
so i don't have the Auto differential disconnect!
thanks for the replies, i'll let ya know how it goes after i get the axles in!
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
87blyota
Jul 8, 2015 09:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
coryc85
Jul 6, 2015 04:07 AM
