Relieving Fuel Pressure
I have a 91 4runner. I looked up "Relieving fuel system pressure" in my Chilton's manual and was surprised at what I read. It says to wrap a clean towel around the union bolt at the fuel delivery rail and slowly loosen the bolt. Isn't this really dangerous?
I was thinking about just disconnecting the fuel pump power or removing the fuse and cranking the engine a few times. I noticed that there's an EFI relay as well as an EFI fuse. Does the relay only control the fuel pump and not the injectors?
Thanks for the help.
I just replaced my engine and when I took the fuel line off, only a couple of drips came out. Nothing to worrie about in my opinion. Maybe first let the vehicle sit for a while, so most of the pressure is gone.
On my '93 there is a small access panel on the floor under the rear passenger seat. If you unscrew that there is a connection for the fuel pump. Undo the connection and run the engine until it quits and the fuel pressure is relieved.
I just replaced my fuel filter and the Hayes manual suggested what you said - remove the fuel pump fuse, start the engine, and then wait till it shuts down from lack of fuel.
My motor wouldn't turn over at all without the fuse, but I cranked it a few times and figured I was good to go. No problems removing the fuel filter.
I'm no professional wrench though
Originally Posted by Schuey2002
So,uhm.. taking off your gas cap won't relieve any pressure on the system??
When I want to bleed the system off, I let it sit for a while, then crack the banjo bolt at the end of the fuel rail. A few drops come out and the pressure is relieved.
Originally Posted by lee
why must one do this? forgive my ignorance
v_man
Jul 23, 2015 04:01 PM
