Regearing
Old Feb 5, 2005 | 02:26 PM
trdeu4ia's Avatar
Regearing
I am wanting to regear my 00 prerunner(v6 auto) and wanted to know from you guys if i go to 4.56 gears what it will basically harm and improve on my truck. i'm clueless with gearing. i'll be running 265/70/16. any help is appreciated.
Old Feb 5, 2005 | 02:29 PM
superjoe83's Avatar
do you know what you have in there currently, some of the taco auto's came with 4.56's stock
Old Feb 5, 2005 | 02:30 PM
trdeu4ia's Avatar
i beleieve the prerunners came with 4.10 but i'm not sure
Old Feb 5, 2005 | 02:32 PM
superjoe83's Avatar
get the code off your drivers door jam by the latch, the code will be something like "B03A" or similar, post what you got for a code
Old Feb 5, 2005 | 02:35 PM
Bob_98SR5's Avatar
trd,
most likely you have 4.10. on the little sticker inside your door jamb, there's a code on the sticker which identifies what you have. i can't remember all the details on which code it is, but if you search here for "gear ratio", theres a few threads that tell you which code to read and what it means.
or, call toyota's 800 number w/ your VIN and they'll tell you over the phone.
bob
Old Feb 5, 2005 | 02:42 PM
trdeu4ia's Avatar
the code says A340E
Old Feb 5, 2005 | 02:47 PM
superjoe83's Avatar
Originally Posted by trdeu4ia
the code says A340E
thats the trans code, i believe the diff code is the last one on the list, it should start with a "B"
Old Feb 5, 2005 | 02:49 PM
Bob_98SR5's Avatar
Originally Posted by Bob_98SR5
...but if you search here for "gear ratio", theres a few threads that tell you which code to read and what it means.
c'mon, do the leg work yourself, man!
Old Feb 5, 2005 | 03:11 PM
trdeu4ia's Avatar
i found out that it has 4.10 gears. so, can anybody just give some info if i go to 4.56 gears such as pros and cons. will it affect the locking diff?
Old Feb 5, 2005 | 03:27 PM
superjoe83's Avatar
going to 4.56's from 4.10's is not that much of a jump, you will have slightly better acceleration, but will be turning higher freeway RPM than you would with 4.10's, so your gas mileage may go down, it will not affect the locker at all
Flying91
45
Apr 11, 2024 04:39 PM
charlie_fong
Sep 27, 2015 10:06 PM
Mike Maiato
Aug 28, 2015 02:35 AM
Higbee89
Aug 27, 2015 06:52 AM
calrockx
Jun 21, 2004 09:22 AM
