reducing shifter throw? short shifter kit? cut down actual shifter?
Old Nov 30, 2004 | 02:55 PM
dexter's Avatar
so after driving home and back i have realized that the throw on my shifter is huge and really anyoning especially after driving my girl friends jetta and my buddies wrx with a short shifter. I was wondering if anyone makes a short shifter kit for our 4runners or if it would help having the shift lever cut down and rethreaded.
thanks
Old Nov 30, 2004 | 02:58 PM
desert whomper's Avatar
cutting it is the easy way around, the best way is to move the whole system up therefore giving more leverage on the internals.... wait im rambling on, lc engineering makes one, check it out.
Old Nov 30, 2004 | 03:22 PM
Chapman88SR5's Avatar
can someone post a link to this?
Old Nov 30, 2004 | 03:24 PM
WolfpackTLC's Avatar
Cutting and rethreading will not only reduce your leverage, but will also screw up your shifter geometry. Don't do it.
Old Nov 30, 2004 | 03:27 PM
dexter's Avatar
k saw the lc thing thats cool but which will make a bigger difference? include price into the factor (having it cut and reathreaded will be max 50 bucks or so)
Old Nov 30, 2004 | 03:29 PM
dexter's Avatar
how will it change the geometry it is staright from where it corves to the top a good 5-8 inches thta ican see taking off like 3-4 inches shouldnt make much of a difference
rimpainter.com's Avatar
A body lift will shorten the height of the stick, so to speak.
dexter's Avatar
but i dont want a lift if anything im gonna drop it an inch when my new wheels come in
Old Nov 30, 2004 | 03:31 PM
My bad. Check ebay, they might have something.
Old Nov 30, 2004 | 03:37 PM
Albuquerque Jim's Avatar
B & M makes an actual short throw shifter for our trucks. Here is a write up.
B & M Short Shifter
Old Nov 30, 2004 | 04:10 PM
ianshoots's Avatar
Short throw? I want more throw! My first car, a 1971 Volvo 142 Coupe had a four speed with a shifter that was nearly two feet long. It was like driving a tractor....I miss that car......sometimes.
Old Nov 30, 2004 | 06:06 PM
Flamedx4's Avatar
There are numerous short throw shifter conversions out there. Try www.marlincrawler.com
I have theirs for the trans and tcase, and love them. Well worth the $ and cheaper than the others anyway.
But, if all you want is to shorten the lever (it doesn't make much difference in the shifter throw really, just makes it shorter) just pull it and ask a welding shop to shorten it. They say you shouldn't do this, but if the suspension components are welded together I think the shifter will be fine... Mine is welded, the previous owner put the 3" BL in and lengthened the shifter 3" (2 welds) So after the short throw install, it was too tall, so I cut out 3" and welded it again. (different spots though...) Just be sure they don't get it hot enough to melt the glue holding the outer upper section in place or it'll come apart.
Old Aug 24, 2007 | 12:24 PM
4Crawler's Avatar
I run short throw kits on both my tranny and t-case shifters:
http://www.4crawler.com/4x4/ForSale/...wShifter.shtml
http://www.4crawler.com/4x4/ForSale/...ter/index.html
Works very well, makes it easier to reach the forward gears without leaning up out of the seat back while driving.
Old Aug 24, 2007 | 12:32 PM
Elton's Avatar
holy old thread batman
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
Iceman4193
Jul 15, 2015 04:48 PM
crashburnoveride
Jul 10, 2015 06:39 AM
