Which Redline fluids to use where?
Old Dec 13, 2004 | 01:52 PM
dynamo's Avatar
It seems that every store I call has no idea what kind of fluid to use in my tranny/diff/transfer case. The truck is a 2000 4Runner LTD. I was given several choices by both shops I called, and I can't find any relevant info on this site or redline.com. Can someone please help me out and tell me what exactly do I need?
Old Dec 13, 2004 | 02:25 PM
Bob_98SR5's Avatar
look under 'specifications' in the back of your owner's manual
bob
Old Dec 13, 2004 | 02:28 PM
jimbo74's Avatar
diff and tranny normally use gear oil, and the tranny uses gear oil or atf depending on auto or stick...
Old Dec 13, 2004 | 02:35 PM
dynamo's Avatar
From what I have gathered so far, I need Redline ATF for the tranny, and the Redline gear lube 75/90 for the transfer cases and the diffs. Now if I could only figure out the quantities - all the sources I am going to (shops and write ups) are listing different quantities. Help please!
Old Dec 13, 2004 | 02:44 PM
User 051420's Avatar
IIRC, my xfer case takes ATF.....
Old Dec 13, 2004 | 02:47 PM
jimbo74's Avatar
it really depends on the truck.... if i had a tcase, it would take gear oil.... my stick tranny is supposed to have gl4 not gl5 gear oil while the rear is supposed to have gl5 gear oil
Old Dec 13, 2004 | 02:49 PM
dynamo's Avatar
I have a t-case, and unless the last three people I talked to are dead wrong, I need the gear oil.
Old Dec 13, 2004 | 05:12 PM
Noliwan's Avatar
Did you read up on Bob_98SR5 write up--- the type & quantity of gear lube you require is correct on his charts with the exception of the Auto Tranny which uses ATF 16 qts. if doing a complete flush 2 - 3 qts. if just drain & fill-- they are the same listed on the 2000 4Runner owners manual that I have... the brand (flavor) of lube that you want to use is the only thing you have to consider-- I use AMSOIL... but there are many other good synthetics...
Old Dec 13, 2004 | 06:57 PM
keisur's Avatar
So... I'm guessing it's safe to say you didn't learn anything from this thread:
https://www.yotatech.com/forums/f2/servicing-differential-transfer-case-46085/
Old Dec 13, 2004 | 10:20 PM
dynamo's Avatar
https://www.yotatech.com/forums/showthread.php?t=46085
I did, and am taking it in for a complete flush tomorrow. I was a bit thrown off by the fact that the shop told me they would use 16qt to do the tranny flush, especially since I got completely different numbers from threads here and other places. Now that it's confirmed, I get to pay $240 for the complete Amsoil tranny flush, and do the rest myself.
Thanks for the help keisur and everyone else.
ladybugRC
458
Aug 21, 2020 10:41 AM
zanzabar0
Oct 11, 2015 02:56 AM
bradahman
Oct 1, 2015 09:24 AM
gentry
Sep 28, 2015 06:16 AM
old87yota
Sep 9, 2015 12:39 PM
