Rear Speaks
Old Nov 10, 2002 | 10:03 PM
NerfHerder-97SR5-'s Avatar
Rear Speaks
What is the largest size anyone has fit, not only as in width but depth, in the rear doors of their Runners?
My roomate found a awesome deal on some alpine type R 6 1/2's
Will they work? and if so....Can I fit even larger or is that about the extent i can cram in back there?
Old Nov 11, 2002 | 10:24 AM
excellent...so no one here has upgraded their rear speaks or knows the largest width and depth I can fit?
Superb.
Old Nov 11, 2002 | 10:30 AM
CTB's Avatar
CTB
Try searching over at Outdoorwire..I know this topic has been discussed over there a bunch of times.
Old Nov 11, 2002 | 10:32 AM
rowan's Avatar
i think it's been discussed here too. im not sure but i think the biggest width was 5.5" or maybe that's stock. you can always do some trimming.
Old Nov 11, 2002 | 11:06 AM
Nitro Hotpants's Avatar
i just replaced mine about a month ago with MB quarts. i think the size they said they put in was 4". now thats not very big at all i was very surprised. they might be a little bigger, but that was the size the shope by me said they were.
P.S. i already blew out my rear MB Quarts so i wouldnt suggest those in the rear if you are going to be powering your speakers with an amp
-Casey
Old Nov 11, 2002 | 12:09 PM
pfdaxe's Avatar
I put 5 1/4" Kenwood components in my rears without trimming. Anything bigger you'll have to start cutting.
Paul
Old Nov 11, 2002 | 01:01 PM
Outkast`'s Avatar
I was able to throw, well my friend moreso while I observed some 5.25" speakers back there, and that was without any custom work or cutting. I called Crutchfield and they told me that I would need to 'fabricate' a bracket of some sort. Problem is that the speakers are already in and work fine. Hope this helps.
Outkast`
Old Nov 11, 2002 | 01:23 PM
Jason B's Avatar
Supposedly the rears are 4". I squeezed in 5 1/4's no problem. I would also suggest adding tweeters to the rear as well. This really helps with the rear fill.
Old Nov 11, 2002 | 07:57 PM
Appreciate it everyone, I'll be staying away from those Alpine Type R 6 inchers.
Old Nov 11, 2002 | 11:52 PM
DuB's Avatar
DuB
It all depends on the speaker set. Each company makes their speakers with different size brackets. For instance, I had JL 6.5" in my front doors that fit on the stock baffle with just a 1/4" spacer. I'm in the process of replacing them with Dyn equivalents (MW160). These things have a huge basket so I have to rebuild the factory baffle and bring it out some more as well.
That said, people have been able to squeeze 6.5s back there, but most go with 5.25s. Check out the size of the TypeR's baskets and see what you have to work with int he door.
found some specs on their website.
http://ecominet2.alpine-usa.com/html...r-174a_ptg.pdf
http://ecominet2.alpine-usa.com/html...r-176a_ptg.pdf
okamikai
Apr 30, 2018 10:19 PM
HollieJayyy
Aug 9, 2015 07:59 AM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
mlavery85
Jul 12, 2015 10:33 AM
