Rear Hatch Cig Lighter
Old Aug 14, 2003 | 06:08 AM
Ducky's Avatar
Question Rear Hatch Cig Lighter
Anyone know if this has a seperate fuse anywhere, all my cig outlets work, just not that rear one....
Old Aug 14, 2003 | 06:12 AM
Erc's Avatar
Erc
Silly question, but did you have the key turned to "acc" when you tried it? It won't work in off position.
Sorry, don't know about separate fuse for it.
Old Aug 14, 2003 | 06:14 AM
Ducky's Avatar
Yea... Its on... hrm... crap guess ill have to start searching around.
Old Aug 14, 2003 | 06:29 AM
Corey's Avatar
Co-Founder/Administrator
Ducky, have you used it recently?
I know on the older rigs like mine, the stock one up front uses a fusable link wire within a few inches of the outlet on the power wire.
It it blows, no juice.
That happened on my '90 truck I use to have, and I simply eliminated the fusable link altogether.
Yours may have one back by the outlet in the power wire, and it could have blown from running something to long back there.
I blew my mine out using an air compressor.
Old Aug 14, 2003 | 06:30 AM
Memphis4X4's Avatar
Check the outlet itself. The cig lighter outlet in my truck has a "fuse" in the outlet assembly. It is a small wire-fuse on the back of the outlet. Mine blew/melted when I was running a air compressor.......I searched the fuse panel and found no blown fuses. It wasn't until I removed the outlet and inspected it that I found that 'fuse' int he outlet had blown. I "repaired" mine by soldering in a wire jumper in place of the melted wire-fuse......I felt that the fuse in the fuse box should prevent any fire hazard
Hope this helps.
David
Old Aug 14, 2003 | 06:34 AM
Ducky's Avatar
I think I know what did it too
Ill check to see if thats the case and jump it....
make a long story short, when welding my sliders on I only disconnected my neg terminal.... heh... It prolley got smoked by the welder...
:pat:
SMOD
Jul 27, 2015 01:45 PM
TDonkey
Jul 26, 2015 10:14 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
daddio
Jul 18, 2015 10:20 AM
icentropy
Jul 14, 2015 10:23 AM
