rear axle housing swap from rolled 4runner
Old Mar 21, 2010 | 09:05 PM
Yota Yeti's Avatar
I have a 97 V6 with 4.30 gearing open diff. I picked up a 99 axle housing (drum to drum) with E locker and supposedly 4.30 gearing. The guy rolled is 4 runner and was parting out the truck and I got lucky ($300)at least I am hoping so.
I have torn it apart and put it back together, other than the diff and gearing.
The axles appear to turn fine and nothing appears to have been damaged from the rollover, however anybody have any tips on what I should investigate before I swap them out, other than confirming the gear ratio?
Old Mar 22, 2010 | 06:58 AM
BajaRunner's Avatar
Well you'd assume the links would fail before bending the axle housing, but you can never know.
If you are unsure, I know you can simply modify your current housing by notching the pumpkin opening to accept a locking diff. I don't know if I could say "simply" since I have never done it, and it seems like some people feel its a PIA.
Old Mar 22, 2010 | 07:12 AM
Yota Yeti's Avatar
My intention is to swap the housing and use my axles, brakes etc and keep the other axles as spairs.
6th Gear
19
Dec 10, 2019 07:31 AM
DanStew
Jun 29, 2015 10:46 AM
Niameyrider
Jun 25, 2015 05:50 AM
AustinTaco
Jun 21, 2015 09:54 AM
Leonel
Jun 13, 2002 02:42 PM
