Rare Dash Lights??? Pics
Old Dec 13, 2007 | 10:11 AM
GOH10 Runner's Avatar
Well First the dash lights are out In my A/C, ECT, Rear Defog, and Rear Window Buttons. I removed the dash panel and all the buttons and took the lights out and tried to find them at both dealers in my area....both have never seen them and tried to tell me I had to buy a whole new A/C Button and Panel that houses the rest of the lights.
Im wondering has ANYONE seen or know where to find these bulbs or a panel.
The first is the panel that works the ECT, RD, and RW.
These are the three lights: 1st is the light out of the A/C button, 2nd is the rear window, 3rd is the ECT and RD which did have a green cap on it.
Old Dec 13, 2007 | 10:23 AM
frodin1's Avatar
No, they are available. Search on here, because people have changed all their interior lights to LED. The LED's fit with no modification. You should be able to find the thread, it'll give you the part numbers and places to get the bulbs. Goodluck!
Old Dec 13, 2007 | 01:22 PM
element's Avatar
These are common bulbs for Toyotas and Hondas. The parts guys at the dealer must have been having a bad day. I have heard the bulbs referred to as "neo wedge" by Honda guys.
You can source these on line at http://autolumination.com
Specifically under their heading for "37 74 Gauge & Instrument Panel & Neo-Wedge Bulbs" found here.
Save the old bulbs because you will probably need to switch the bulb covers over to keep your dash lighting up the same color.
These two posts may have some useful information:
https://www.yotatech.com/forums/f2/g...ghting-117226/
https://www.yotatech.com/forums/f2/0...-bulbs-106658/
Old Dec 13, 2007 | 01:27 PM
Fo_SheeZy's Avatar
The big long one, I have no idea? But for the smaller ones, those are Neo-wedge, now there are three types, you migt want to measure, for my 02 it's a Type A on autolumination.com
Old Dec 22, 2007 | 04:29 PM
So I ended up buying all new LED dash lights but Im clueless on how to do the gauge or window switch lights.... what types of bulbs are used, is it easy to do?
Old Dec 22, 2007 | 10:54 PM
Fo_SheeZy's Avatar
The window switch lights are weird... I have no idea about them, I couldn't figure it out. As for the gauge lighting, different years have different sized bulbs, I know the 02 takes three 194's as for the 99.. I'm not sure?
Old Dec 24, 2007 | 12:30 PM
how many were there?
Old Dec 24, 2007 | 05:39 PM
JGrauman's Avatar
does the rear defog light up when not in use? my em flasher button does, but think i have a bulb out in the defog button, it only lights up when it's active. i can't see the thing at night.
Old Dec 25, 2007 | 07:59 AM
It is supposed to be lit at night and then when pushed a little orange bar lights up too.
Old Dec 25, 2007 | 10:40 AM
Fo_SheeZy's Avatar
So did you find a replacement bulb for that really long one?
Old Dec 25, 2007 | 11:34 AM
im gonna try two things...one of the normal wedge ones and I bought a twist lock base that you use with one of the 74s
Old Dec 25, 2007 | 04:19 PM
dibble9012's Avatar
You could modify the LED neo-wedge bulb to fit in the long one. Just remove the LED and resistors from the one you get from autolumination. Lengthen the leads and replace the incandescent bulb from the truck with the new LED. (in the long base)
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sep 4, 2015 09:27 AM
highonpottery
7
Jul 18, 2015 02:48 PM
Johntom240
7
Jul 13, 2015 12:18 AM
bryan34w
Jul 6, 2015 05:53 PM
