Ram Air question
Old Dec 15, 2004 | 03:39 PM
gbpec7's Avatar
Ram Air question
What Ram Air intakes does the best job? I have a 92 pickup with a 22RE and I'm looking at these at FBI Mini and this one on eBay. Your opinions are greatly appreciated.
Thanks
Old Dec 15, 2004 | 03:45 PM
Those aren't Ram Air systems, they're "cold air" intakes. Which will have limited benefit, since they're drawing air from around a toasty-hot motor. Ram Air is a scoop that collects the air from in front of the vehicle as you drive, to shove more in - which on a 22re is worthless anyway since you have to be haulin ass for Ram Air to do anything.
Save your money, is what I'm getting at.
Old Dec 15, 2004 | 03:51 PM
gbpec7's Avatar
Ok, I stand corrected....
What do you use to filter intake air?
Old Dec 15, 2004 | 03:55 PM
TRunner's Avatar
The system you are looking at on ebay is the filter. Instead of utalizing an air box so silence sound, it creates a better environment for sucking air into the engine and will give you a bit more torque. It will also be louder.
Old Dec 15, 2004 | 04:10 PM
PirateFins's Avatar
like he said save your money. I have not gained anything out of having straight pipe to the TB. Think about it this way. You are taking hot air from the engine bay and running it thru a metal pipe that runs along top out your hot hot radiator. So what happens to the pipe and the "Cold Air" that is inside of it? It heats up more.
What you can do is. Remove the top of your airbox, pull out the filter. Remove the elbow at the bottom of the box. Go a step further and remove the S-pipe that goes between the box and headlight. Pour some water to cover the botom of the box and drill 1/4" holes in the bottom till all the water has drained from the low spots. Replace filter with a performance filter like an Amsoil or K&N (got mine for $20 new on ebay). Replace top of airbox and enjoy. You will have a larger unrestricted opening in your box that is still getting most of its "cold air" from the headlight area, and a nice new intake note. Then you can send me some money instead of spending $150.
Look at this post for pics and detail
Old Dec 15, 2004 | 04:12 PM
Yamaha+Toyota=Fun's Avatar
You can make somthing like fairly simply, if you going to be going offroad id advise you to stick with the airbox and just do a deckplate mod, and amsoil filter. You can also swap the airbox and Battery. Doing all 3 of those mods and you probally will get a pretty good hp gain and keep the water outa your motor. You can do the whole thing for around 50 bucks too.
Here are some picture of what it looks like.
Old Dec 15, 2004 | 05:53 PM
gbpec7's Avatar
Thanks for all the replies. No one here hasen't had any benefits from either of these two items? I wont be going off road with my truck, it's just driven on the street.
Thanks for the link PirateFins
Old Dec 15, 2004 | 06:38 PM
Chapman88SR5's Avatar
yamaha+toyota beat me to it
u could probably get even more fancier with this and make a heat shield
Old Dec 15, 2004 | 06:42 PM
YotaTruck1986's Avatar
Staying Onroad? I use a similar system to Yamaha+Toyota=Fun. Planning on fabbing a better pipe to go between the box and TB.
Old Dec 15, 2004 | 07:13 PM
Yeah, my airbox to T.B. is a bit getto
Old Dec 15, 2004 | 07:40 PM
gbpec7's Avatar
Nice truck YotaTruck1986. My air box is on the driver side. I have alot of room to change out my stock air box to a K&N filter.
Old Dec 16, 2004 | 09:18 AM
Flamedx4's Avatar
So were theirs. That's what they are showing - swapping the battery to the other side and putting the airbox closer to the intake. Yamaha's smooth elbow will help a lot too, but the squished and twisted pipe in YT86's probably hurts more than the mod would have helped.
Old Dec 16, 2004 | 09:39 AM
gbpec7's Avatar
Oh,ok...so what is better, a short pipe or a long one? I thought the long one would be better for torque.
Old Dec 16, 2004 | 11:50 AM
From what my butt tells me, it's provided a well needed kick in the pants off the line compared the congested stock air box.
Old Dec 16, 2004 | 01:44 PM
Flamedx4's Avatar
Zactly, the length of the pipe from the airbox to the intake isn't a really big deal, it's the restrictive convolutions and the restricted air box inlet that do the most harm. Longer intake runners just prior to the air intering the cylinders generally IS good for more torque though.
Old Dec 16, 2004 | 03:22 PM
gbpec7's Avatar
Ok, I'll get/make a long one and try it. If I can't really notice much difference then I'll do like the rest of you have done and move my battery to the driver's side and make a short one. I'll post back to this thread my results.
Thanks for the help......
Old Dec 17, 2004 | 10:41 AM
Flamedx4's Avatar
No no no, the pipe from the airbox to the intake is not the intake runners - that's integral to the cast aluminum intake manifold and there isn't much you can do about it. Opening up your airbox will make the biggest gain for the least effort (deck plate mod, extra holes, whatever,) especially combined with a good filter.
Old Dec 17, 2004 | 01:45 PM
gbpec7's Avatar
Ok, I get it. What it this "deck plate" mod?
I think what I'll do is just change to a K&N filter and see how that goes for now.
Thanks.
Old Dec 17, 2004 | 03:15 PM
search it in the tech write ups, its basically cutting a hole, or multiple holes, in the deck plate for more airflow
Old Dec 17, 2004 | 06:30 PM
PirateFins's Avatar
Thanks.
The decklate mod is what I pointed you to in the other linked post. You can cut a 4" hole in the box and put in a boat deckplate to be able to seal it up. I f you are not going to off road the cut a 4" hole in the box ans be done with it.
Link to deck plate post HERE
