Question on wheel bearings
Old Sep 18, 2005 | 04:37 PM
Keggo's Avatar
I just bought Timken bearings for the front of my truck. I got the inner cup, inner cone, inner seal, and set 47 outer bearings. My question is this. Since none of the local auto stores sell Timken outer seals, is it possible to use say a Beck & Arnely outer seal? I'm going to be installing new cv's, new bearings, and my manual hubs tomorrow. Thanks!
Old Sep 18, 2005 | 04:40 PM
JamesD's Avatar
Sure you can as long it is for the application you can use any name brand seal you want. I was only aware of one seal on the rotor and that is the inner.
James
Old Sep 18, 2005 | 04:45 PM
Keggo's Avatar
Really? cool. I'll check the FSM just to be sure! I appreciate it! Welcome to Yotatech! I saw that you only have 6 posts... thanks again for the help! Also, what will I need for the adjusting nut? Isn't it pretty big?
Old Sep 18, 2005 | 05:45 PM
Adam F's Avatar
54mm socket, or a 2 1/8 socket, which you can find at Sears for $25 or so.
Also I think AutoZone rents axle nut sockets, try them.
Yea, there is no outer wheel bearing seal, just the inner. There is the hub gasket seal though. Probably a dealer only part.
Old Sep 18, 2005 | 06:10 PM
Keggo's Avatar
Yeah, I got the hub assembly to wheel gasket. Thanks for the info. I'll see if Autozone has em!
Old Sep 18, 2005 | 09:41 PM
Keggo's Avatar
After reading some other posts, I'm thinking it is probably the spindle bushing that has worn out, causing this problem. I'm going to put my new cv's in and take a look at my existing wheel bearings tomorrow. If the wheel bearings are not corroded, pitted, rusted, worn down, etc... I'm going to repack them with grease, refund the brand new wheel bearings I bought, and drive around the block to see if the clunking sound is still there. If it is... then crap, I have to spend my whole next day off replacing that dam ned steering spindle bushing. :cry: Anyone near Bakersfield want to help me out if that's the case? So... tired... of... doing... repairs... on... truck... need... money... for... fun!! :cry:
Old Sep 19, 2005 | 09:22 AM
Yoda's Avatar
There is an updated roller bearing avail for this.
Toyota TSB DL94-001 issued in 94 (90-94 runners/trucks)
It is to reduce noise in the axle in "extreme cold" conditions, but I like the thought of a bearing over a brass bushing.
90364-30011 roller bearing (2 needed to do both sides)
90381-32001 thrust bushing (2 needed to do both sides)
bearing grease
Dealer may be able to print the directions for you. I could mail them, they won't "cut and paste" from my info source.
Old Sep 19, 2005 | 09:54 AM
Keggo's Avatar
Hm... that would be great if you could mail them. If it's a TSB, it won't be free to fix, would it? I'd rather have a bearing than a brass bushing also... sheesh! heh heh... I'll pm you my address... thanks!
Old Sep 19, 2005 | 11:47 AM
celica's Avatar
bearing grease
Noise in extreme cold conditions. This sounds like my problem. I have been to a few dealers and they don't have a clue. When it is really cold I have a moaning sound come from my axels until it warms up. It has always done it and I haven't had any issues. Does anyone else have this problem? What is the fix
Matt
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
PlayAwhile
Jul 20, 2015 11:36 AM
rushw
Jul 18, 2015 01:46 PM
87turboPA
Jul 12, 2015 07:49 AM
