push button 4wd question
Old Mar 25, 2008 | 06:59 AM
highmilesrunner's Avatar
in my old SR5, if i needed to take the console apart to change bulbs or whatever, i unscrewed the top of the 4wd button. now in my limited it has the pushbutton feature which the SR5 didn't. if i need to get behind the console area again, can i still just unscrew this too? i would think not since it has the pushbutton mechanism. just curious...
Old Mar 25, 2008 | 08:12 AM
98runner210's Avatar
I believe there is a screw in the handle.
Old Mar 25, 2008 | 08:29 AM
Rock Slide's Avatar
It can be removed in the same manner (one screw holding it on). I've removed mine a dozen times or more to access areas behind the dash.
Old Mar 25, 2008 | 12:01 PM
so i take out a screw located somewhere on the handle/knob area then it screws right off?
Old Mar 25, 2008 | 12:44 PM
Rock Slide's Avatar
yep, you got it.
The screw is located on the driver side of the shift knob. Unscrew it and you can slip the shifter right off the stalk.
Old Mar 25, 2008 | 01:08 PM
sounds good. i appreciate it rock slide!
westonian18
May 1, 2020 06:38 AM
jasonty
41
Dec 23, 2018 01:00 PM
RustBucket
Jul 24, 2015 04:46 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
