push button 4wd question
in my old SR5, if i needed to take the console apart to change bulbs or whatever, i unscrewed the top of the 4wd button. now in my limited it has the pushbutton feature which the SR5 didn't. if i need to get behind the console area again, can i still just unscrew this too? i would think not since it has the pushbutton mechanism. just curious...:think:
I believe there is a screw in the handle.
It can be removed in the same manner (one screw holding it on). I've removed mine a dozen times or more to access areas behind the dash.
so i take out a screw located somewhere on the handle/knob area then it screws right off?
yep, you got it. :)
The screw is located on the driver side of the shift knob. Unscrew it and you can slip the shifter right off the stalk. |
sounds good. i appreciate it rock slide!
