Pulley Help Needed.
Old Mar 5, 2004 | 07:52 AM
Faded's Avatar
Pulley Help Needed.
I originally had this in the Maintenance Forum, but I was hoping to get a quick answer so I could order parts ASAP. It seems like the Maintenance Forum doesn't get the exposure like this one. I'm sorry if the double post is offensive.
Since I have the front of my motor tore apart I was going through and checking things out that might be in need of some attention. I don't know jack about A/C systems and my A/C pulley makes some noise when spun by hand. (Sorry, kind of hard to hear but it's there)
See It Here
If so, what all needs to be replaced and how hard is it to do it? It looks like you can remove the one 10mm bolt in the center, but I'd like some advice first. Someone recommended that it might be possible to just replace the bearing? Any further thoughts on this would be appreciated. Thanks in advance.
I also think I need a timing belt idler pulley as well.
Thanks,
Andrew
Old Mar 5, 2004 | 01:25 PM
Faded's Avatar
bump...
Old Mar 5, 2004 | 01:44 PM
86toyota's Avatar
You should be able to just replace the front baering if that's what's making noise.You also have to remove a circlip if I remember corectly and it should just slide off.Prolly have to get the dealer to order it thou.
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
EVars
Sep 29, 2015 02:06 PM
voiddweller
Sep 28, 2015 11:21 PM
Corvoid
Sep 14, 2015 10:10 AM
