Protection for 99+ stock fog lights foglights?
Old Jan 8, 2008 | 09:49 AM
cackalak han's Avatar
No, I don't stutter. Just making it easier for people to find in the future.
Anyway, noticed that my driver's side fog light is shattered (probably from rocks flying up at it), and of course, the bulb is out. So looks like I'll have to fork up $70-100 or whatever the cost is to replace these. Anyone know of a mesh grill or something that will add some protection? I was also thinking of going with a thick layer of lamin-x (lamin-x.com). I'd hate to have to replace them in the future.
Also, I will probably replace the bulb to a yellow color while I'm in there. Seems to work better compared to the OEM white light (comparing mine to my friend's Lexus).
Old Jan 8, 2008 | 10:00 AM
pdyebrasil's Avatar
I'm very interested in this as well... My sister just got a 99 4Runner and both of the fog lights were busted. Somewhat strange considering there is no damage to the valence. Seems like someone just punched them out. Is this a fairly common occurrence? I know that on Durangos the left fog light is prone to breaking... but that's a mounting bracket issue.
Anyway, I found some replacements and would like some protection for them as well.
Old Jan 8, 2008 | 10:09 AM
Snookster's Avatar
I just replaced one of my fogs. I got one off ebay and the guy said he didnt know if it worked.so I figured the the parts from this one and the old one I could make it work. Plugged it in and it worked. can't beat a new fog for $15 shipped. Mesh grille might work, but I can't see it looking good
Old Jan 8, 2008 | 10:15 AM
I think if no one has any better suggestion, I'm going to just get some lamin-x in clear 40mil, and cut to fit. One sheet should be good for both. I might even look into getting some for the headlights, too.
Old Jan 8, 2008 | 05:13 PM
jimbob's Avatar
<<< Quick Hijack >>>
Can someone shed some light on how to remove the factory lights? I've got a busted drivers side lens and I've looked looked at the mounting brackets and for the life of me, I can't figure out which screws to remove to drop the housing out I've got to be missing something simple...
Old Jan 8, 2008 | 08:39 PM
It should be just an 8mm bolt holding it up. You have to remove the harness, too, before removing.
Old Jan 9, 2008 | 04:46 AM
gpcollen1's Avatar
I suppose I would be interested in what people are using these days as far as aftermarket fog lights. I know there used to be a kit around for $150 or so but I cannot find that one with my existing saved links. $300-$400 just seems to much for some stinkin fog lights.
Old Jan 9, 2008 | 01:32 PM
Deceptiwave's Avatar
In a similar situation myself. Busted outter lense, but light works. I am going to get a sheet of clear polycarbonate plastic and make a new lens.
Should work OK, poly is good to about 212* and I doubt those little lights get that hot.
Old Jan 9, 2008 | 02:29 PM
Jason Burtman has some on his site.
http://www.burtmanindustries.com/zoo...4run_fog_99_02
Let me know how that works out. I'm not too up on my plastics. Where can you get that? Home Depot? Would plexiglass work? And what would you seal it with?
Old Jan 9, 2008 | 05:20 PM
jimbob's Avatar
This is where I found them - as soon as I figure out how to remove it, I'll order a replacement (and maybe a spare).
Doh!!! - heres the link --- http://www.rallylights.com/hella/Mic...p#Micro_DE_HID
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
RatOmeter
Oct 22, 2015 03:17 PM
