power rear window???
Old Feb 25, 2005 | 12:51 PM
xSLICKx's Avatar
Question power rear window???
My rear window has worked just fine untill recently. All of a sudden it only works going up and not down. Maybe just a coincidence, but it stopped working after replacing my liscence plate lights. Suggestions???
Old Feb 25, 2005 | 01:08 PM
Silver_Truck's Avatar
Blown fuse maybe? Don't have a 4runner so I don't know all the specifics but that's what I can think of, or maybe a short?
Old Feb 25, 2005 | 01:10 PM
Bob_98SR5's Avatar
slick,
try searching the term "rear panel removal" and every variation you can think of. several members have had this problem w/ the window not rolling up and down. you'll have to examine the window mechanism from the back. several threads discuss how to remove the panel.
bob
Old Feb 25, 2005 | 01:53 PM
Flamedx4's Avatar
It always helps to tell us what year. In my 85 I had that problem reglarly from the console switch, but not the key. Road debris would break the wires where the harness goes from the tailgate to the body. I had to fix it at least every 3 years. If it goes one way but not the other, both from the key and the switch in the console, the problem is probably in the tailgate.
Old Feb 25, 2005 | 03:39 PM
xSLICKx's Avatar
My truck is a 96' SR5
Old Feb 25, 2005 | 03:42 PM
eric-the-red's Avatar
You're in Winterpeg, it's probably just frozen and anyway in a few months the flies will be out and you won't want the window down.
More seriously it could be the control module, it has a relay for up and one for down. If it still works one way the motor is obviously OK. The control module just swaps the polarity to the motor so it runs the opposite way. Try removing the inner panel and lube the bits that move, see if that helps.
I have the service manual in pdf for 2nd gen 4runners, if you want a copy send me an email address.
Edit, just noticed you have a '96, my manual may not help, but you're welcome to try it.
Old Feb 25, 2005 | 08:17 PM
jtm994's Avatar
mine is messed up to it wont go up and down and gets no power to it. i was told it was the relay switch and if a shop replaced it the labor would be a crazy amount so i just havent got it fixed and it started messin up about a year ago
Old Feb 25, 2005 | 09:12 PM
If it is a relay the labour to change that would be less than 1 hour, but I've heard the control module is an expensive part. The module contains 4 or 5 relays and a bunch of other resistors and stuff, and I don't think you can just replace one relay.
Old Feb 27, 2005 | 02:02 PM
xSLICKx's Avatar
Damn thing fixed itself. dont ask. I dont know ???
Old Feb 27, 2005 | 04:31 PM
dragon564's Avatar
The relay box is a known gripe on the all the gen2. I have seen posts on other boards that cover how to remove and repiar the box. It comes down to 1 or 2 of the relays going out and they are not the best relays to begin with....the post I saw used replacement relays from RADIO SHACK.. Check 4x4 wire I think that is where I saw it...
Old Feb 27, 2005 | 06:51 PM
Flamedx4's Avatar
Just amazing. I remember when nothing had a "control module" and what a coincidence, never broke down either.
Old Feb 27, 2005 | 07:26 PM
amorphous's Avatar
no...i believe you!
mine did the the same thing....only, mine did the "auto roll down" feature...it would NOT go up....ended up using a 12v "wall wart" to roll it up...then ordered a "new used" relay box 'cos I didn't like the $35x.xx that the dealer wanted for the part. - GOT the part....and rehooked up the motor....and....it had FIXED itself!
crazy, but true. It was REALLY freaking cold when that happened - which was preceded by really warm...and I wheeled...got REALLY muddy, then sprayed the truck off, it got SUPA cold (zero and stuff) then all my locks froze, then I used de-icer....then the window thing. Then it "healed" itself...
I chock it up to the 4x4 pixies!
aaron
Old Feb 27, 2005 | 09:13 PM
JoKEpLaYeR's Avatar
I was hoping for an answer. Mine isn't rolling up or down.....
Old Feb 28, 2005 | 03:49 AM
amorphous's Avatar
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
that may help!
aaron
Old Mar 1, 2005 | 04:19 PM
xSLICKx's Avatar
When mine wasn't working it was a little cold, not too bad though(-25,-35windchill). It was working the day before so it wasn't frozen. When I pushed up I could hear the motor so I knew that it was still working, but down, well a whole lotta nothing. Then two days later I pushed the button for no apparent reason and magical ˟˟˟˟˟˟ing things happened. It's a good thing I love my truck, or else I would have smashed the damn window. Oh ya, -40,-50 windchill is what cold is here in Winterpeg
Old Mar 1, 2005 | 05:51 PM
amorphous's Avatar
Ouch - that is friggin C O L D !!!
yeah...i don't know HOW I could live without my rear window and sunroof!
A
Old Mar 1, 2005 | 06:57 PM
green91runner's Avatar
glad it was just a poor contact, wish mine were that simple.. inside the cab it works great.. go to use the key, and nada.. but I dont think its the electrical connections, probably just the tumbler, doesn't budge when i try to turn it. such a pain
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
coryc85
Jul 6, 2015 04:07 AM
