portable tire changer
Old May 28, 2005 | 10:19 PM
jimbo74's Avatar
my tire changer cost $40... you cannot by beadlocks for anywhere near that!.... i also don't know anyone who has gotten a ticket for it, doesn't mean it wont happen... jsut liek the poeple that run 1200 watt linears on their cbs, is it legal? nope, will they ever get caught? its possible, but why chance it ... however, i dont need beadlocks, and i dont have the $ to spend on it either.....
Old May 31, 2005 | 10:07 AM
jimbo74's Avatar
so whats everyone think of my design modifications?
Old May 31, 2005 | 11:37 AM
4Crawler's Avatar
I guess if they work then they are good. I had no problems with mine in stock form. I guess if I run into some of those problems, I'll have some ideas on how to fix it.
Old May 31, 2005 | 08:54 PM
jimbo74's Avatar
ok.... used it for real tonight, swapped out my balding 235s with some 50% tread left 31" muds i had in the backyard..... here is the report: the tire changer does its job, but its CRUDE.... had to use brute strength.... and luckily i used to work @ a tire place and have a little bit of technique and know how.... if someone with no experience wanted to try to use this thing, i would advise against it.... also its little footprint sucks... the whole thing tried to spin on me..... had to hold it down with my feet whiel trying to spin it..... i got both tires mounted.... but pretty much ended up just mounting them without the changer... the big ole bar that came with the changer was awesome though......
some people said that they had an idea about making a mount to mount it to a trailer hitch, this would be an AWESOME idea.... and once i get a hitch, i am going to do that.... that would make it A LOT easier to deal with....
Old May 31, 2005 | 09:04 PM
  #25
4Crawler's Avatar
I bolted mine to the concrete slab on my patio. Nice thing is I can move 360 degrees around it. I found that some real tire bead lube and a big brush make for easier mounting. I've done about a half dozen tires now, it does take a little pratice to get the hang of it, especially which way the end of the bar goes for mounting and demounting.
Also used it on my bead locks, while not 100% necessary, it does make life easier. Gets the wheel up in the air and very secure so you can wrestle the tire over the inner bead.
Old May 31, 2005 | 09:35 PM
  #26
jimbo74's Avatar
yeah i didnt have any lube, jsut used some dishwashing soap... and i know what im doing, i mounted tires for probably well over 3 years total..... other than it moving on me, it worked.... but it jsut moved too much for me.... the idea for putting it on a hitch would be awesome
firstgen88
Oct 7, 2015 04:53 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
Scatterbrain
Sep 3, 2015 06:46 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
