Poor acceleration problems---advice needed
Old Jul 27, 2005 | 03:48 AM
glassfishy's Avatar
Now that I have my 91 Runner back up and running (new engine) my 94 Runner 4WD has decided to start giving me problems. Just like children. I started noticing a poor acceleration problem about 2 months ago, but it was gradual. Now it's driving me crazy. It's always when I leave a light or start out driving. Sometimes it doesn't act up at all and sometimes I can hit the gas and nothing. It continues to do it even if engine is hot. The other day I was at a stop light and it wouldn't go anywhere. I had to let off the gas and it finally kicked in.
I've replaced plugs and plug wires. I did the Seafoam thing (gas tank and PCV hose). The next thing on the list (from Toyota PDF Problem Checklist) is EGR Valve. Can you guys think of anything else I should be checking before I tear into the EGR valve? I hate taking off the Air Intake if I don't have to disturb it. I'd really like to try and fix this myself without giving someone else all my money.
As always thanks guys!!
Steve
Glassfishy@gbronline.com
Old Jul 27, 2005 | 07:39 AM
94x4's Avatar
Guest
My guess would be to try checking the air intake/filter to be honest with you.... you'll be looking for oil deposits.
Old Jul 27, 2005 | 07:48 AM
4Crawler's Avatar
TPS and AFM are two another things to check: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old Jul 27, 2005 | 08:04 AM
Beartracker's Avatar
What about the gas filter? Mike
Old Jul 27, 2005 | 08:29 AM
leiniesred's Avatar
When is the last time you changed out those spark plugs? Start with the easy stuff.
Old Jul 27, 2005 | 08:36 AM
4RocRunner92's Avatar
94x4 said something about the Air intake and oil deposits. That happened to me. My intake wasn't mounted level so the oil that the throttle body was supposed to suck in at the top of the intake had collected in my MAF. Which resulted in a new MAF and new intake. So DEF check that out! :o
Old Jul 27, 2005 | 03:48 PM
glassfishy's Avatar
I just did that on Monday night. It seemed to up my idle a bit, but nothing on acceleration.
Steve
Old Jul 27, 2005 | 03:50 PM
glassfishy's Avatar
That was one of the things I was wondering about also. Also the Gas Pump? It feels to me (and I'm not good an decipering problems with a car) like there's air or something in the gas lines. Like it takes it a bit for the gas to get through the lines. But then I thought if that was the case wouldn't the car die due to lack of gas?
Steve
Old Jul 27, 2005 | 03:51 PM
glassfishy's Avatar
Thanks guys. I'll check out all these things. Any other ideas? Keep em coming.
steve
Old Jul 27, 2005 | 03:52 PM
glassfishy's Avatar
Originally Posted by 4Crawler
My first thought was my mass air flow sensor, and it still may be that. I had mine go out on my 91 runner and my car would almost die at a stop light. I might take mine off my 91 and put it on the 94 to see if that helps.
Steve
Old Jul 27, 2005 | 09:32 PM
94x4's Avatar
Guest
I'd move on to the injectors and then the TPS (Throttle Position Sensor), which seems to be hitting alot of people lately.
Old Jul 28, 2005 | 02:25 PM
glassfishy's Avatar
I switched out the AMF's last night. No help. I went today to buy a fuel filter. I figured that was a cheap easy thing to try. But I have one question. Does anyone know where it's located. I'm going to try and swap it out tonight after work and any help in locating the son of a buck would be helpful. I checked out the Service PDF and couldn't find anything on the filter. My Haynes manual talks about the 4 cyl, but doesn't tell actually where the filter is. Anyone quickly know the whereabouts?
Old Jul 28, 2005 | 02:28 PM
4Crawler's Avatar
Between #3 and #4 cylinders, passenger side of the block, above the starter. Access panel can be removed in the wheel well. You can see the shiny black filter in the image below, above the blue oil filter:
Old Jul 28, 2005 | 02:38 PM
94x4's Avatar
Guest
Wow!! 4Crawler hit it again, with pictures and all no less.
You 'da man, Mr. Brown!!
Old Jul 28, 2005 | 02:46 PM
glassfishy's Avatar
I was a bit confused at first. It took me a second to realize the oil filter was on the wrong side. I think I might have confused everyone. I said the Haynes manual shows where the filter is in a 4cyl, but I failed to say it doesn't show where it is in a V6 3.slow. that's what I'm working on. I think I found my answer though. I did a search (which I should have done first) in the tech writeup and found out how to do it.
Thanks for the photo. I love this group. Everyone so willing to help out.
steve
Old Jul 28, 2005 | 02:53 PM
94x4's Avatar
Guest
Shame on you for not "Searching" first, that'll be two demerits for you mister, now go to the back of the line.
Old Jul 28, 2005 | 07:05 PM
glassfishy's Avatar
ONe other question. In the tech write up it doesn't say anything about putting any type of sealant or tape on threads to keep from leaking. Do I need to worry about this or just put it on.
Old Jul 28, 2005 | 08:04 PM
Axo's Avatar
Axo
I had similar issue once that cleared up on it's own. The suggested problem before I had to dig into was simply debris build up in the gas tank. As our vehicles get older there is a greater possibility of debris plugging the fuel pick up.
Just a thought...
Old Jul 29, 2005 | 02:59 AM
94x4's Avatar
Guest
You should'nt have any worries as it has "compression" fittings like those on pretty much all plumbing fixtures, just tighten according to spec.
Old Jul 29, 2005 | 11:09 AM
glassfishy's Avatar
Just a thought...
So what did you do? Drop fuel tank and clean out and reinstall? Anything else?
