Pics of 97 4run to 99 4run headlight and airbox conversion
Old Feb 10, 2008 | 05:56 AM
toytech76's Avatar
Originally Posted by 111db
About the AFM / MAF. I checked your thread on U/Y (I'm not a member there) and it seems easy enough. Do you need the later year airbox or will that MAF fit my stock 97 airbox?
Another question for you and MTL4Runner. A little background: had a p0130 code, replaced the O2 sensor, CEL came back with a 171. Reset numerous times with no fix. Cleaned MAF & reset, CEL came back at idle. My AFM is reading 2088 ohms at 71.5 deg F. From the table below it seems it should read under 2000 ohms. Dynamic test seems ok. Info from the FSM:
AIRFLOW METER RESISTANCE TABLE
Temperature Ohms
-4 F (-20 C) ............................... 10,000-20,000
32 F (0 C) ..................................... 4000-7000
68 F (20 C) .................................... 2000-3000
104 F (40 C) .................................... 900-1300
140 F (60 C) ..................................... 400-700
176 F (80 C) ..................................... 200-400
From your experience, is 100 ohms out of spec enough to be causing this code? It would appear so. My next debate is whether to change to the later model year AFM
Yes you do need the later year airbox and it can come from a tacoma or a 4runner because they are the same. If you get a used one it may or may not come with a MAF. If it doesnt you will need to buy a new one from toyota which is about $130. Also make sure it has the screws for the MAF. If not you can get them at home depot. The box bolts right up and hooks right into your stock intake hose. Make sure you repin your connector per my posting. Your code PO171 is most likely caused from your MAF. I have honestly never done an ohms test on a maf. Anytime a PO171 comes up 90% of the time is a bad MAF. Other times its been a random vac leak. You can either go to the new setup or if you want to stick with your current setup I have my used 97 MAF for sale here which is in good cond. If you need anymore help with the new box/maf setup, let me know!
Old Feb 10, 2008 | 08:05 AM
arjan's Avatar
That Ohm reading looks within spec to me.
If your particular MAF reads closer to 3000Ohm at 68F then at 71.5 it can still be above 2000Ohm
Old Feb 10, 2008 | 08:49 AM
toytech76's Avatar
according to the chart it isnt reading correctly. I would check all your hoses then do your swap
Old Feb 10, 2008 | 04:13 PM
toy_tek's Avatar
Yeah I was thinking it should be reading closer to 1900 ohms or so by that chart. I double checked all the vacuum lines on the intake and everything looks intact.
Guess I'll look around for some parts.
Old Feb 10, 2008 | 04:18 PM
  #25
CASTAIC 4RUNNER's Avatar
Sweeeet!
Old Feb 10, 2008 | 05:14 PM
  #26
toytech76's Avatar
Let me know if you need any help with your new setup when you get parts!
Old Feb 10, 2008 | 06:48 PM
  #27
soo euro's Avatar
I wish i would have known they had the headlights there for that cheap. I need some for my 97 runner. I work in the same building at the Volkswagen/ Audi yard.
Old Feb 10, 2008 | 06:52 PM
  #28
toytech76's Avatar
Well I only got them at that price because the buckets were damaged. Normally I think they are $75 each for good ones. They get new runners in all the time so check with him and tell him you are from yotatech so you will get a discount
Old Feb 12, 2008 | 05:01 AM
  #29
Ritzy4Runner's Avatar
Very interested in the mod you described at the beginning of the thread but I can't see any pics either here or the linked site. Would consider the mod but need to know everything I will need to get out of a 3rd gen flight 2 (99-02). I have been doing a sort of mod conversion on my 98, center console was the start and now working on the radio bezel, got a complete radio bezel with the wiring harness/connectors. Head lights are next when I can find a pair that arn't going to cost me $100. Been wanting to do the cold air ram but the kits for my year runner are very hard to find. Seems if I can find the 2nd flight MAF and connector, I could just go directly to the newer cold air intake. I could use the wire/pins set up for a conversion. Thanks
Old Feb 12, 2008 | 05:08 AM
  #30
toytech76's Avatar
I looked and all the pics are working. Not sure why you cant see them. For the airbox conversion all you need is a 99-02 4runner/tacoma airbox and MAF sensor. That all bolts right in without any modification. As far as the connector, the linked site tells you what color wire goes where in the connector. Its pretty easy. Only 4 of the 5 wires need to be moved around. Let me know if you need any help with it!
Old Feb 12, 2008 | 10:53 AM
  #31
Jdizzydub's Avatar
Sweet looking upgrades, sounds really good at 70 too!
Old Feb 12, 2008 | 10:58 AM
  #32
kylextrisler's Avatar
that is an awesome truck, my engine might be going out soon (go figure huh? an unreliable 3vz) thats about what i want my next truck to be...
Old Feb 12, 2008 | 11:18 AM
  #33
4rnr4nick's Avatar
hey toytech, what kind of lift, and tires do you have on there? looks REALLY good
and how much were the supra mafs when you looked? just curious...
Old Feb 12, 2008 | 06:24 PM
  #34
toytech76's Avatar
Thanks! I have the revtek 3" on the front plus another 3/8-1/2 spacer on top of the studs. In the rear I have front 97 land cruiser coils and shocks. The tires are 33x12.5/15 pro comp mud terrains and the rims are the pro comp 15X8 1069 alloys. We should get all the sac area people together and check out each others trucks. I actually never priced the supra maf's just because I figured no one would have one and that they were kind of expensive. I got my whole airbox setup for $50 so that was cheaper and easier
Old Mar 25, 2008 | 06:24 PM
  #35
toy_tek's Avatar
Got the later model airbox & MAF but forgot to get the screws. Do you remember what size they are? Going to re-pin now...
{edit] Re-pin was simple. Hex cap screws are 4mm x 20mm, picked up those & lock washers at HD for $1.00.
Old Mar 25, 2008 | 08:19 PM
  #36
toytech76's Avatar
How do you like it now?
Old Mar 25, 2008 | 08:44 PM
  #37
toy_tek's Avatar
Eh, garage door spring broke, truck stuck inside. I'll let you know in a few days.
Old Jan 3, 2009 | 08:41 PM
  #38
Elton's Avatar
old thread and all but i just did the 99-up air box conversion got the parts cheap off ebay had to search for awhile but i got the box with intake for $35shipped.... and a good working maf for $8 dollars shipped yes i said 8 dollars.... the wiring is pretty simple works great and has a little more power and that's with out the deck plate mod but i do have all that tube crap taken out of the fender
Old Jan 3, 2009 | 08:48 PM
  #39
4banginRunner's Avatar
Badask 4Runner! I love clean lifted 3rd gens
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
landes94
Aug 16, 2015 12:20 PM
mldave
Aug 10, 2015 09:23 AM
priest16
15
Aug 6, 2015 07:43 AM
