perma-cool vs. TRD tranny cooler
Old Jul 29, 2003 | 07:07 AM
4RunnerFever's Avatar
I'm about due for the 60,000 mile tune and thought it would be a good idea to have a transmission cooler installed. Every S/C guru on this board recommends it at least.
My question is should I pony up for a TRD? I don't race, hardly ever tow or go off-road (:chicken.
Seems like the medium duty perma-cool from Performance Products might be the way to go. For $40 bucks, seems like a deal compared to over $200 for the TRD.
Any suggestions or advice is much appreciated.
Old Jul 29, 2003 | 07:14 AM
TDiddy's Avatar
With the TRD tranny cooler, you're paying $150+ for a fancy mounting bracket.
The Perma-cool style I believe is the tube and fin type, OK but not the best.
They way to go is to order a Hayden Transaver Plus stacked plate style cooler. Its rumored that Hayden manufactures the TRD coolers anyway, just not sure if that's confirmed.
I ordered one from Makco Distributing and just installed it this past saturday. I went with model 1678, heavy duty.
Old Jul 29, 2003 | 07:15 AM
tomstin's Avatar
Hayden, stack plate, I have the 30k cooler installed http://www.dcflags.com/MM001.ASP?pageno=84 After talking to Hayden, Level 10 and Amsoil, I found that it's pretty hard to over-cool ATF, particularly Synthetic ATF. You want the coolest possible AFT returning to the A/T. Easy install. One tip, go find some 3/8 ATF hose, and make sure it's ATF rated. The 11/32 that ships with the Hayden is REAL tough to get on the Toyota 3/8 fittings...save yourself a busted knuckle or two!
Measure the available areas on your truck to see which size will work for you. I ended up mounting mine upside down to clear the hood latch! Made for a long hose run!
Old Jul 29, 2003 | 07:17 AM
Hyperlite's Avatar
The cheeper one should be fine, i you really think you need one. The temp in the high country is usually under 80 but I guess the traffic on King Street can make any tranny hot.
Do you live in Banner Elk and Teach at Lees McRea?
Old Jul 29, 2003 | 07:24 AM
Keep the advice coming on the cooler. I'll definitely look into the Hayden. Any idea on costs?
Hyperlite - yes to both of your questions
We should get ssbogger, you and me together sometime (and any other wnc folks).
Old Jul 29, 2003 | 07:26 AM
TDiddy's Avatar
Mine was $51 shipped.
Old Jul 29, 2003 | 07:48 AM
Hyperlite's Avatar
I graduated last December in business and have talked to you about your S/C. I knew by looking at those fog lights. When
Iwas there drove a black 97 4Runner
I live on Lake Norman Now, not bad for a LMC grad. Some WNC trails to go to are Tellico, the Globe and Westbowl (4ROC hopefully will orginize a trail run there soon)
This week I will probible order the cheep tranny cooler and a temp guage at the same time, kill 2 birds w/ same stone.
Old Jul 29, 2003 | 08:50 AM
pfdaxe's Avatar
I agree with mertztr & tomstin. I also bought mine at http://www.dcflags.com/MM001.ASP?pageno=84
I also have the 30,000 lb. cooler model #DC1679...$51.91
They shipped very fast and install was pretty easy. I followed the write-up from the tech section. You can't beat the price and quality.
I have a ton of TRD items on my Runner, but the trans cooler is waaay over priced. They charge upwards of $200 for what is actually a Hayden cooler that still isn't as big as my $51 Hayden cooler from the site above. It was a tough decision for me. Spend $200 and get a cool looking TRD box or save $150 and get an even better one....Hmmmmm. The stacked plate coolers are the way to go. The one from PP isn't as good. I went with the biggest I could get with living in Phoenix and having a s/c. I figure it doesn't hurt.
Old Jul 29, 2003 | 10:04 AM
I'm convinced, Hayden it is.
Hey PFDAXE - your runner is one, if not, my favorite on the board. FWIW - cool truck!
Hyperlite - I remember. Congrats on the cool lake living. Do you know Jeff Gordon or Dale Jarret??
Old Jul 29, 2003 | 10:41 AM
pfdaxe's Avatar
Thanks mgspann:
I don't think you can go wrong with the Hayden and can't overkill with purchasing a cooler. Your tranny will love you for it. Be sure to read the install write up as this helped alot.
https://www.yotatech.com/~corey/tech...ler/cooler.htm
http://www.hboss.net/4runner/tranny-cooler-install.htm
Let us know how the install goes. Remember to add more fluid as you'll need some extra.
Paul
ashamsuddin
17
Jul 22, 2024 03:59 AM
ladybugRC
458
Aug 21, 2020 10:41 AM
Steven.m.paulk
Jun 7, 2020 10:45 AM
scott90
Oct 4, 2015 09:21 AM
LCE_Performance
Oct 1, 2015 01:03 PM
